[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 11:24:53 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.colors/main.c
          Function
find_rule(Begins at: 86, Ends at:95)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
list_rules(Begins at: 78, Ends at:84)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
main(Begins at: 97, Ends at:386)
Complexity:   |      39 |   *** |      MONSTER |        39 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     108 |   *** |      MONSTER |       108 |
LOC:          |     290 |   *** |      MONSTER |       290 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
rules_list(Begins at: 52, Ends at:76)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
scan_rules(Begins at: 36, Ends at:50)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 11:36:05 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
