[GRASS-QA] GRASS QA: martinl |Vect.h dig_externs.h read.c write.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 11:27:44 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/include/Vect.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/include/vect/dig_externs.h
          File :grass/branches/develbranch_6/lib/vector/Vlib/read.c
          Function
format(Begins at: 30, Ends at:34)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
read_next_dummy(Begins at: 24, Ends at:27)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_area_alive(Begins at: 156, Ends at:162)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Vect_isle_alive(Begins at: 173, Ends at:179)
metrics are OK
Vect_line_alive(Begins at: 122, Ends at:128)
metrics are OK
Vect_node_alive(Begins at: 139, Ends at:145)
metrics are OK
Vect_read_line(Begins at: 95, Ends at:111)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      17 |       |           OK |        17 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Vect_read_next_line(Begins at: 70, Ends at:82)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/lib/vector/Vlib/write.c
          Function
delete_dummy(Begins at: 36, Ends at:41)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
format(Begins at: 44, Ends at:48)
metrics are OK
rewrite_dummy(Begins at: 30, Ends at:35)
metrics are OK
Vect_delete_line(Begins at: 205, Ends at:236)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
Vect_rewrite_line(Begins at: 145, Ends at:171)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
Vect_write_line(Begins at: 99, Ends at:125)
metrics are OK
write_dummy(Begins at: 24, Ends at:29)
metrics are OK
Clone analysis:
          File :grass/branches/develbranch_6/lib/vector/Vlib/write_nat.c
          Function
add_area_cats_to_cidx(Begins at: 57, Ends at:83)
metrics are OK
delete_area_cats_from_cidx(Begins at: 29, Ends at:55)
metrics are OK
V1_delete_line_nat(Begins at: 544, Ends at:573)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
V1_rewrite_line_nat(Begins at: 356, Ends at:401)
LOC:          |      46 |     * |      WARNING |        46 |
metrics are OK
V1_write_line_nat(Begins at: 99, Ends at:113)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
V1__rewrite_line_nat(Begins at: 446, Ends at:533)
Complexity:   |      21 |   *** |      MONSTER |        21 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      88 |     * |      WARNING |        88 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
V2_delete_line_nat(Begins at: 584, Ends at:772)
Complexity:   |      35 |   *** |      MONSTER |        35 |
CalledNBR:    |      45 |   *** |      MONSTER |        45 |
LOC:          |     189 |   *** |      MONSTER |       189 |
metrics are OK
V2_rewrite_line_nat(Begins at: 417, Ends at:432)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
V2_write_line_nat(Begins at: 126, Ends at:334)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     209 |   *** |      MONSTER |       209 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 11:38:56 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
