[GRASS-QA] GRASS QA: martinl |Vect.h dig_externs.h read.c write.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Oct 2 11:30:22 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/Vect.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/include/vect/dig_externs.h
File :grass/trunk/lib/vector/Vlib/read.c
Function
format(Begins at: 30, Ends at:34)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a OK |
metrics are OK
read_next_dummy(Begins at: 24, Ends at:27)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_area_alive(Begins at: 155, Ends at:161)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 7 | | OK | 7 |
metrics are OK
Vect_isle_alive(Begins at: 172, Ends at:178)
metrics are OK
Vect_line_alive(Begins at: 121, Ends at:127)
metrics are OK
Vect_node_alive(Begins at: 138, Ends at:144)
metrics are OK
Vect_read_line(Begins at: 95, Ends at:110)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a WARNING |
metrics are OK
Vect_read_next_line(Begins at: 70, Ends at:82)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/Vlib/write.c
Function
delete_dummy(Begins at: 36, Ends at:41)
LOC: | 6 | | OK | 6 |
metrics are OK
format(Begins at: 44, Ends at:48)
metrics are OK
rewrite_dummy(Begins at: 30, Ends at:35)
metrics are OK
Vect_delete_line(Begins at: 205, Ends at:236)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 32 | | OK | 32 |
metrics are OK
Vect_rewrite_line(Begins at: 145, Ends at:171)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 27 | | OK | 27 |
metrics are OK
Vect_write_line(Begins at: 99, Ends at:125)
metrics are OK
write_dummy(Begins at: 24, Ends at:29)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/write_nat.c
Function
add_area_cats_to_cidx(Begins at: 56, Ends at:81)
LOC: | 26 | | OK | 26 |
metrics are OK
delete_area_cats_from_cidx(Begins at: 29, Ends at:54)
metrics are OK
V1_delete_line_nat(Begins at: 542, Ends at:571)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 30 | | OK | 30 |
metrics are OK
V1_rewrite_line_nat(Begins at: 354, Ends at:399)
LOC: | 46 | * | WARNING | 46 |
metrics are OK
V1_write_line_nat(Begins at: 97, Ends at:111)
CalledNBR: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
metrics are OK
V1__rewrite_line_nat(Begins at: 444, Ends at:531)
Complexity: | 21 | *** | MONSTER | 21 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 88 | * | WARNING | 88 |
Conclusion: | this function is a MONSTER |
metrics are OK
V2_delete_line_nat(Begins at: 582, Ends at:770)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 45 | *** | MONSTER | 45 |
LOC: | 189 | *** | MONSTER | 189 |
metrics are OK
V2_rewrite_line_nat(Begins at: 415, Ends at:430)
metrics are OK
V2_write_line_nat(Begins at: 124, Ends at:332)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 209 | *** | MONSTER | 209 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 11:41:34 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
