[GRASS-QA] GRASS QA: martinl |main.c plot1.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Thu Oct 9 04:43:39 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/display/d.rast/main.c
Function
main(Begins at: 32, Ends at:144)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 38 | *** | MONSTER | 38 |
LOC: | 113 | ** | BABY-MONSTER | 113 |
Conclusion: | this function is a MONSTER |
metrics are OK
parse_catlist(Begins at: 146, Ends at:176)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a WARNING |
metrics are OK
parse_d_mask_rule(Begins at: 241, Ends at:270)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 30 | | OK | 30 |
metrics are OK
parse_mask_rule(Begins at: 210, Ends at:239)
metrics are OK
parse_vallist(Begins at: 178, Ends at:208)
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/display/d.vect/plot1.c
Function
local_plot_poly(Begins at: 48, Ends at:69)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 22 | | OK | 22 |
metrics are OK
plot1(Begins at: 129, Ends at:530)
Complexity: | 60 | *** | MONSTER | 60 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 94 | *** | MONSTER | 94 |
LOC: | 402 | *** | MONSTER | 402 |
metrics are OK
plot_polygon(Begins at: 102, Ends at:124)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 23 | | OK | 23 |
metrics are OK
plot_polyline(Begins at: 74, Ends at:97)
CalledNBR: | 5 | | OK | 5 |
LOC: | 24 | | OK | 24 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 09 04:56:19 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
