[GRASS-QA] GRASS QA: martinl |colors.c display.c local_proto.h main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 9 04:58:03 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.rast/colors.c
          Function
color_list(Begins at: 4, Ends at:17)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
get_rgb(Begins at: 19, Ends at:30)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/display/d.rast/display.c
          Function
cell_draw(Begins at: 46, Ends at:92)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      47 |     * |      WARNING |        47 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
display(Begins at: 12, Ends at:44)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
mask_raster_array(Begins at: 94, Ends at:103)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Clone analysis:
          File :grass/trunk/display/d.rast/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/display/d.rast/main.c
          Function
main(Begins at: 35, Ends at:137)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |     103 |       |           OK |       103 |
metrics are OK
parse_catlist(Begins at: 139, Ends at:169)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       9 |     * |      WARNING |         9 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
parse_d_mask_rule(Begins at: 234, Ends at:263)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
parse_mask_rule(Begins at: 203, Ends at:232)
metrics are OK
parse_vallist(Begins at: 171, Ends at:201)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       9 |    ** | BABY-MONSTER |         9 |
LOC:          |      31 |    ** | BABY-MONSTER |        31 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 09 05:10:42 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
