[GRASS-QA] GRASS QA: neteler |main.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Fri Oct 24 23:27:10 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/raster/r.sun_horizon/r.sun2/main.c
          Function
calculate(Begins at: 1723, Ends at:2132)
              |          New Metrics           |Old Metrics|
Complexity:   |      64 |   *** |      MONSTER |        64 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      94 |   *** |      MONSTER |        94 |
LOC:          |     410 |   *** |      MONSTER |       410 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
com_declin(Begins at: 2136, Ends at:2146)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
cube(Begins at: 1716, Ends at:1718)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       3 |       |           OK |         3 |
metrics are OK
distance(Begins at: 183, Ends at:192)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
INPUT_part(Begins at: 753, Ends at:1152)
Complexity:   |      93 |   *** |      MONSTER |        93 |
CalledNBR:    |     128 |   *** |      MONSTER |       128 |
LOC:          |     400 |   *** |      MONSTER |       400 |
joules2(Begins at: 1369, Ends at:1489)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |     121 |    ** | BABY-MONSTER |       121 |
Conclusion:   | this function is a  BABY-MONSTER           |
main(Begins at: 199, Ends at:750)
Complexity:   |      39 |   *** |      MONSTER |        39 |
CalledNBR:    |     133 |   *** |      MONSTER |       133 |
LOC:          |     552 |   *** |      MONSTER |       552 |
OUTGR(Begins at: 1154, Ends at:1332)
Complexity:   |      41 |   *** |      MONSTER |        41 |
CalledNBR:    |      64 |   *** |      MONSTER |        64 |
LOC:          |     179 |   *** |      MONSTER |       179 |
test(Begins at: 2150, Ends at:2164)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
where_is_point(Begins at: 1543, Ends at:1571)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      29 |       |           OK |        29 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Oct 24 23:43:04 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
