[GRASS-QA] GRASS QA: martinl |null.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Fri Oct 24 23:29:22 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.null/null.c
          Function
doit(Begins at: 290, Ends at:334)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      45 |     * |      WARNING |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
main(Begins at: 15, Ends at:183)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      61 |   *** |      MONSTER |        61 |
LOC:          |     169 |   *** |      MONSTER |       169 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
parse_d_mask_rule(Begins at: 217, Ends at:245)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      29 |       |           OK |        29 |
 at least 3 values are close to an outlier please consider revising code!
parse_vallist(Begins at: 185, Ends at:215)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
 at least 1 values are close to an outlier please consider revising code!
process(Begins at: 247, Ends at:288)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      42 |     * |      WARNING |        42 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Oct 24 23:45:16 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
