[GRASS-QA] GRASS QA: martinl |main.c | 3 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Oct 24 23:31:36 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.null/main.c
          Function
doit(Begins at: 309, Ends at:357)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        20 |
LOC:          |      49 |     * |      WARNING |        45 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
main(Begins at: 28, Ends at:202)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      75 |   *** |      MONSTER |        61 |
LOC:          |     175 |   *** |      MONSTER |       168 |
Conclusion:   | this function is a       MONSTER           |
parse_d_mask_rule(Begins at: 236, Ends at:264)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      12 |     * |      WARNING |        10 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
parse_vallist(Begins at: 204, Ends at:234)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
 at least 1 values are close to an outlier please consider revising code!
process(Begins at: 266, Ends at:307)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      42 |     * |      WARNING |        42 |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file has 3 potentially cloned functions:
  parse_d_mask_rule  process
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/null.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/main.c clones of parse_d_mask_rule are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/null.c  parse_d_mask_rule
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/main.c clones of process are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.null/null.c  process
____________________________________________
Threshold grass key metrics values at Fri Oct 24 23:47:31 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
