[GRASS-QA] GRASS QA: pkelly |input.c local_proto.h main.c output.c |
20 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Sep 4 15:17:43 EDT 2008
Hello pkelly,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/general/g.proj/input.c
Function
input_currloc(Begins at: 42, Ends at:51)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
input_epsg(Begins at: 162, Ends at:181)
CalledNBR: | 8 | | OK | 8 |
LOC: | 20 | | OK | 20 |
metrics are OK
input_georef(Begins at: 202, Ends at:256)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 55 | * | WARNING | 55 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
input_proj4(Begins at: 113, Ends at:145)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a WARNING |
metrics are OK
input_wkt(Begins at: 68, Ends at:95)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 28 | | OK | 28 |
metrics are OK
set_default_region(Begins at: 262, Ends at:284)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 23 | | OK | 23 |
metrics are OK
set_gdal_region(Begins at: 293, Ends at:333)
CalledNBR: | 5 | | OK | 5 |
LOC: | 41 | | OK | 41 |
metrics are OK
set_ogr_region(Begins at: 342, Ends at:367)
CalledNBR: | 2 | | OK | 2 |
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
This file has 16 potentially cloned functions:
input_currloc input_epsg input_epsg input_georef input_georef input_proj4 input_proj4 input_wkt input_wkt set_default_region set_default_region set_gdal_region set_gdal_region set_ogr_region set_ogr_region
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of input_currloc are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c input_currloc
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c input_currloc
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of input_epsg are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c input_epsg
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c input_epsg
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of input_georef are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c input_georef
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c input_georef
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of input_proj4 are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c input_proj4
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c input_proj4
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of input_wkt are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c input_wkt
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c input_wkt
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of set_default_region are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c set_default_region
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c set_default_region
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of set_gdal_region are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c set_gdal_region
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c set_gdal_region
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/input.c clones of set_ogr_region are:
/tmp/grassSVN/grass/trunk/general/g.proj/input.c set_ogr_region
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/input.c set_ogr_region
File :grass/trunk/general/g.proj/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/general/g.proj/main.c
Function
main(Begins at: 27, Ends at:241)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 55 | *** | MONSTER | 55 |
LOC: | 215 | *** | MONSTER | 215 |
Conclusion: | this function is a MONSTER |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/general/g.proj/output.c
Function
check_xy(Begins at: 221, Ends at:229)
CalledNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
metrics are OK
create_location(Begins at: 146, Ends at:219)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 74 | * | WARNING | 74 |
metrics are OK
print_datuminfo(Begins at: 49, Ends at:91)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 43 | * | WARNING | 43 |
metrics are OK
print_proj4(Begins at: 93, Ends at:125)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 9 | | OK | 9 |
metrics are OK
print_projinfo(Begins at: 28, Ends at:47)
metrics are OK
print_wkt(Begins at: 127, Ends at:144)
CalledNBR: | 7 | | OK | 7 |
LOC: | 18 | | OK | 18 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
print_proj4 print_projinfo print_wkt
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/output.c clones of print_datuminfo are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/output.c print_datuminfo
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/output.c clones of print_proj4 are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/output.c print_proj4
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/output.c clones of print_projinfo are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/output.c print_projinfo
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.proj/output.c clones of print_wkt are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/general/g.proj/output.c print_wkt
____________________________________________
Threshold GRASS6 key metrics values at Thu Sep 04 15:29:55 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
