[GRASS-QA] GRASS QA: glynn |datum.c | 7 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Sep 4 15:27:18 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/proj/datum.c
Function
free_datum_list(Begins at: 392, Ends at:406)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
GPJ_free_datum(Begins at: 378, Ends at:384)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 7 | | OK | 7 |
metrics are OK
GPJ_get_datum_by_name(Begins at: 37, Ends at:58)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 22 | | OK | 22 |
metrics are OK
GPJ_get_datum_params(Begins at: 136, Ends at:145)
LOC: | 10 | | OK | 10 |
metrics are OK
GPJ_get_datum_transform_by_name(Begins at: 230, Ends at:310)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
LOC: | 81 | * | WARNING | 81 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
GPJ_get_default_datum_params_by_name(Begins at: 85, Ends at:111)
LOC: | 27 | | OK | 27 |
metrics are OK
GPJ__get_datum_params(Begins at: 174, Ends at:216)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 43 | * | WARNING | 43 |
Conclusion: | this function is a WARNING |
metrics are OK
read_datum_table(Begins at: 322, Ends at:370)
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 49 | * | WARNING | 49 |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
GPJ_get_datum_by_name GPJ_get_datum_params GPJ_get_datum_transform_by_name GPJ_get_default_datum_params_by_name GPJ__get_datum_params read_datum_table
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of free_datum_list are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c free_datum_list
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of GPJ_get_datum_by_name are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c GPJ_get_datum_by_name
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of GPJ_get_datum_params are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c GPJ_get_datum_params
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of GPJ_get_datum_transform_by_name are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c GPJ_get_datum_transform_by_name
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of GPJ_get_default_datum_params_by_name are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c GPJ_get_default_datum_params_by_name
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of GPJ__get_datum_params are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c GPJ__get_datum_params
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/datum.c clones of read_datum_table are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/datum.c read_datum_table
____________________________________________
Threshold GRASS6 key metrics values at Thu Sep 04 15:39:30 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
