[GRASS-QA] GRASS QA: glynn |Text.c | 7 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 10:50:56 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/cairodriver/Text.c
          Function
Cairo_draw_text(Begins at: 84, Ends at:99)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a            OK           |
metrics are OK
Cairo_font_info(Begins at: 251, Ends at:255)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Cairo_font_list(Begins at: 245, Ends at:249)
metrics are OK
Cairo_set_encoding(Begins at: 217, Ends at:223)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Cairo_set_font(Begins at: 205, Ends at:215)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Cairo_text_box(Begins at: 101, Ends at:119)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
convert(Begins at: 13, Ends at:66)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      54 |     * |      WARNING |        54 |
metrics are OK
font_list_toy(Begins at: 225, Ends at:243)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
is_toy_font(Begins at: 194, Ends at:203)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
set_font_fc(Begins at: 151, Ends at:174)
LOC:          |      24 |       |           OK |        24 |
metrics are OK
set_font_toy(Begins at: 121, Ends at:147)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
set_matrix(Begins at: 68, Ends at:82)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
  which_item  GS_setall_drawmode  find_rule  GS_setall_drawmode  which_item  GS_setall_drawmode
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Text.c clones of is_toy_font are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.colors/main.c  find_rule
          /var/project-manager/grass/grassSVN/grass/trunk/display/d.save/main.c  which_item
          /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/GS2.c  GS_setall_drawmode
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.colors/main.c  find_rule
          /tmp/grassSVN/grass/trunk/lib/ogsf/GS2.c  GS_setall_drawmode
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.save/main.c  which_item
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/ogsf/GS2.c  GS_setall_drawmode
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 10:56:17 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
