[GRASS-QA] GRASS QA: glynn |display.h draw2.c | 36 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 10:54:08 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/display.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/display/draw2.c
Class
plane(Begins at: 22, Ends at:25)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
rectangle(Begins at: 9, Ends at:15)
Class
vector(Begins at: 17, Ends at:20)
Function
alloc_dst(Begins at: 47, Ends at:56)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
alloc_src(Begins at: 58, Ends at:67)
metrics are OK
box_clip(Begins at: 794, Ends at:810)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a WARNING |
metrics are OK
box_clip_ll(Begins at: 812, Ends at:825)
LOC: | 14 | | OK | 14 |
metrics are OK
clip_plane(Begins at: 119, Ends at:155)
Complexity: | 4 | | OK | 4 |
LOC: | 37 | | OK | 37 |
metrics are OK
clip_polygon_plane(Begins at: 714, Ends at:752)
CalledNBR: | 6 | | OK | 6 |
LOC: | 39 | | OK | 39 |
metrics are OK
coerce(Begins at: 192, Ends at:198)
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
cull_polygon_plane(Begins at: 629, Ends at:672)
LOC: | 44 | * | WARNING | 44 |
metrics are OK
cull_polyline_plane(Begins at: 519, Ends at:562)
metrics are OK
dealloc_src(Begins at: 69, Ends at:83)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
metrics are OK
dist_plane(Begins at: 109, Ends at:112)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
do_clip(Begins at: 157, Ends at:180)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 24 | | OK | 24 |
metrics are OK
do_convert(Begins at: 85, Ends at:107)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
metrics are OK
do_ll_wrap(Begins at: 231, Ends at:250)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
D_box(Begins at: 894, Ends at:906)
CalledNBR: | 9 | | OK | 9 |
LOC: | 13 | | OK | 13 |
metrics are OK
D_box_clip(Begins at: 827, Ends at:836)
metrics are OK
D_clip_to_display(Begins at: 289, Ends at:293)
LOC: | 5 | | OK | 5 |
metrics are OK
D_clip_to_map(Begins at: 323, Ends at:327)
metrics are OK
D_clip_to_screen(Begins at: 305, Ends at:311)
metrics are OK
D_cont(Begins at: 846, Ends at:852)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
D_cont_abs(Begins at: 865, Ends at:868)
metrics are OK
D_cont_abs_clip(Begins at: 466, Ends at:479)
metrics are OK
D_cont_clip(Begins at: 442, Ends at:458)
metrics are OK
D_line(Begins at: 854, Ends at:858)
metrics are OK
D_line_abs(Begins at: 870, Ends at:874)
metrics are OK
D_line_abs_clip(Begins at: 481, Ends at:485)
metrics are OK
D_line_clip(Begins at: 460, Ends at:464)
metrics are OK
D_line_width(Begins at: 908, Ends at:911)
metrics are OK
D_move(Begins at: 838, Ends at:844)
metrics are OK
D_move_abs(Begins at: 860, Ends at:863)
metrics are OK
D_move_abs_clip(Begins at: 345, Ends at:349)
metrics are OK
D_move_clip(Begins at: 339, Ends at:343)
metrics are OK
D_polydots(Begins at: 876, Ends at:880)
metrics are OK
D_polydots_clip(Begins at: 487, Ends at:517)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 31 | | OK | 31 |
metrics are OK
D_polygon(Begins at: 888, Ends at:892)
metrics are OK
D_polygon_clip(Begins at: 783, Ends at:792)
metrics are OK
D_polygon_cull(Begins at: 703, Ends at:712)
metrics are OK
D_polyline(Begins at: 882, Ends at:886)
metrics are OK
D_polyline_clip(Begins at: 615, Ends at:627)
metrics are OK
D_polyline_cull(Begins at: 593, Ends at:605)
metrics are OK
D_set_clip(Begins at: 264, Ends at:277)
metrics are OK
euclidify(Begins at: 200, Ends at:229)
CalledNBR: | 7 | | OK | 7 |
LOC: | 30 | | OK | 30 |
metrics are OK
interpolate(Begins at: 114, Ends at:117)
metrics are OK
line_clip(Begins at: 366, Ends at:390)
LOC: | 25 | | OK | 25 |
metrics are OK
line_clip_abs(Begins at: 416, Ends at:440)
metrics are OK
line_clip_ll(Begins at: 392, Ends at:414)
metrics are OK
polygon_clip(Begins at: 754, Ends at:781)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 28 | | OK | 28 |
metrics are OK
polygon_cull(Begins at: 674, Ends at:701)
metrics are OK
polyline_clip(Begins at: 607, Ends at:613)
metrics are OK
polyline_cull(Begins at: 564, Ends at:591)
metrics are OK
shift_angle(Begins at: 187, Ends at:190)
metrics are OK
shift_count(Begins at: 182, Ends at:185)
metrics are OK
Clone analysis:
This file has 36 potentially cloned functions:
alloc_float alloc_src alloc_int alloc_float alloc_dst box_clip_ll clip_polygon_plane cull_polygon_plane cull_polyline_plane dealloc_float do_clip do_ll_wrap D_box_clip D_cont_clip D_polygon_cull D_polygon_cull D_polygon_clip D_polygon_clip D_polygon_cull D_polygon_clip D_polyline_cull D_polyline_cull D_polyline_clip D_polyline_clip D_polyline_cull D_polyline_clip D_set_clip euclidify line_clip_ll polyline_cull polygon_cull polyline_cull polygon_clip polygon_cull polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_dst are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c alloc_int
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c alloc_float
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c alloc_src
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_src are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c alloc_dst
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of box_clip_ll are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c box_clip_ll
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of clip_polygon_plane are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c clip_polygon_plane
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of cull_polygon_plane are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c cull_polygon_plane
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of cull_polyline_plane are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c cull_polyline_plane
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of dealloc_src are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c dealloc_float
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of do_clip are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c do_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of do_ll_wrap are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c do_ll_wrap
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_box_clip are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_box_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_cont_clip are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_cont_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polygon_cull
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_polygon_cull
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polyline_cull
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_polyline_cull
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_polyline_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polyline_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_set_clip are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c D_set_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of euclidify are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c euclidify
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of line_clip_ll are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/draw2.c line_clip_ll
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polyline_cull
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polygon_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polyline_cull are:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 10:59:29 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
