[GRASS-QA] GRASS QA: glynn |interp.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 11:13:43 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/interp.c
Function
G_interp_bicubic(Begins at: 26, Ends at:38)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a MONSTER |
metrics are OK
G_interp_bilinear(Begins at: 9, Ends at:16)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
G_interp_cubic(Begins at: 18, Ends at:24)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a WARNING |
metrics are OK
G_interp_linear(Begins at: 4, Ends at:7)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:19:05 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
