[GRASS-QA] GRASS QA: glynn |collect_ori.c main.c spread.c | no clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 11:29:19 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/wildfire/r.spread/collect_ori.c
Function
collect_ori(Begins at: 46, Ends at:106)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 12 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 16 | * | WARNING | 17 |
LOC: | 61 | * | WARNING | 59 |
Conclusion: | this function is a WARNING |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/wildfire/r.spread/main.c
Function
main(Begins at: 79, Ends at:579)
Complexity: | 59 | *** | MONSTER | 60 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 211 | *** | MONSTER | 211 |
LOC: | 501 | *** | MONSTER | 490 |
Conclusion: | this function is a MONSTER |
metrics are OK
Clone analysis:
File :grass/trunk/raster/wildfire/r.spread/spread.c
Function
cumulative(Begins at: 168, Ends at:243)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 76 | * | WARNING | 76 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
spread(Begins at: 61, Ends at:162)
Complexity: | 12 | * | WARNING | 13 |
CalledNBR: | 27 | ** | BABY-MONSTER | 28 |
LOC: | 102 | ** | BABY-MONSTER | 100 |
metrics are OK
update(Begins at: 249, Ends at:285)
Complexity: | 7 | * | WARNING | 9 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 14 | * | WARNING | 16 |
LOC: | 37 | | OK | 33 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:34:41 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
