[GRASS-QA] GRASS QA: glynn |main.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 11:31:31 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.extrude/main.c
Function
extrude(Begins at: 380, Ends at:514)
| New Metrics |Old Metrics|
Complexity: | 19 | *** | MONSTER | 19 |
ParamNBR: | 11 | | OK | 11 |
CalledNBR: | 23 | *** | MONSTER | 23 |
LOC: | 135 | *** | MONSTER | 135 |
Conclusion: | this function is a MONSTER |
metrics are OK
main(Begins at: 34, Ends at:356)
Complexity: | 33 | ** | BABY-MONSTER | 33 |
ParamNBR: | 2 | *** | MONSTER | 2 |
CalledNBR: | 127 | ** | BABY-MONSTER | 127 |
LOC: | 323 | ** | BABY-MONSTER | 323 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
main
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extrude/main.c clones of extrude are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extrude/main.c extrude
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extrude/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extrude/main.c main
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:36:53 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
