[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 11:56:18 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.external/main.c
          Class
band_info(Begins at: 35, Ends at:43)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
check_projection(Begins at: 72, Ends at:184)
              |          New Metrics           |Old Metrics|
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
create_map(Begins at: 402, Ends at:440)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      39 |       |           OK |        39 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
list_formats(Begins at: 45, Ends at:70)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      26 |       |           OK |        26 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 442, Ends at:565)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      51 |   *** |      MONSTER |        51 |
LOC:          |     124 |    ** | BABY-MONSTER |       124 |
metrics are OK
make_cell(Begins at: 347, Ends at:365)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
make_link(Begins at: 367, Ends at:400)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      34 |       |           OK |        34 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
query_band(Begins at: 260, Ends at:345)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      86 |     * |      WARNING |        86 |
metrics are OK
setup_window(Begins at: 186, Ends at:232)
LOC:          |      47 |     * |      WARNING |        47 |
metrics are OK
update_default_window(Begins at: 234, Ends at:258)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:01:40 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
