[GRASS-QA] GRASS QA: glynn |main.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 11:54:07 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.extrude/main.c
          Function
extrude(Begins at: 380, Ends at:514)
              |          New Metrics           |Old Metrics|
Complexity:   |      19 |   *** |      MONSTER |        19 |
ParamNBR:     |      11 |       |           OK |        11 |
CalledNBR:    |      23 |   *** |      MONSTER |        23 |
LOC:          |     135 |   *** |      MONSTER |       135 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
main(Begins at: 34, Ends at:356)
Complexity:   |      33 |    ** | BABY-MONSTER |        33 |
ParamNBR:     |       2 |   *** |      MONSTER |         2 |
CalledNBR:    |     127 |    ** | BABY-MONSTER |       127 |
LOC:          |     323 |    ** | BABY-MONSTER |       323 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  main
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extrude/main.c clones of extrude are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extrude/main.c  extrude
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extrude/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extrude/main.c  main
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:59:29 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
