[GRASS-QA] GRASS QA: glynn |cnversions.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 11:46:38 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/display/cnversions.c
          Class
rectangle(Begins at: 26, Ends at:32)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
vector(Begins at: 34, Ends at:37)
          Function
D_a_to_d_col(Begins at: 319, Ends at:322)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
D_a_to_d_row(Begins at: 302, Ends at:305)
metrics are OK
D_do_conversions(Begins at: 69, Ends at:160)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      92 |    ** | BABY-MONSTER |        92 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
D_d_to_a_col(Begins at: 415, Ends at:418)
metrics are OK
D_d_to_a_row(Begins at: 399, Ends at:402)
metrics are OK
D_d_to_u_col(Begins at: 383, Ends at:386)
metrics are OK
D_d_to_u_row(Begins at: 367, Ends at:370)
metrics are OK
D_get_a(Begins at: 244, Ends at:250)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
D_get_a_east(Begins at: 206, Ends at:209)
metrics are OK
D_get_a_north(Begins at: 210, Ends at:213)
metrics are OK
D_get_a_south(Begins at: 214, Ends at:217)
metrics are OK
D_get_a_west(Begins at: 202, Ends at:205)
metrics are OK
D_get_d(Begins at: 252, Ends at:258)
metrics are OK
D_get_d_east(Begins at: 223, Ends at:226)
metrics are OK
D_get_d_north(Begins at: 227, Ends at:230)
metrics are OK
D_get_d_south(Begins at: 231, Ends at:234)
metrics are OK
D_get_d_west(Begins at: 219, Ends at:222)
metrics are OK
D_get_ew_resolution(Begins at: 171, Ends at:174)
metrics are OK
D_get_ns_resolution(Begins at: 167, Ends at:170)
metrics are OK
D_get_u(Begins at: 236, Ends at:242)
metrics are OK
D_get_u_east(Begins at: 189, Ends at:192)
metrics are OK
D_get_u_north(Begins at: 193, Ends at:196)
metrics are OK
D_get_u_south(Begins at: 197, Ends at:200)
metrics are OK
D_get_u_to_d_xconv(Begins at: 176, Ends at:179)
metrics are OK
D_get_u_to_d_yconv(Begins at: 180, Ends at:183)
metrics are OK
D_get_u_west(Begins at: 185, Ends at:188)
metrics are OK
D_is_lat_lon(Begins at: 162, Ends at:165)
metrics are OK
D_u_to_a_col(Begins at: 286, Ends at:289)
metrics are OK
D_u_to_a_row(Begins at: 270, Ends at:273)
metrics are OK
D_u_to_d_col(Begins at: 351, Ends at:354)
metrics are OK
D_u_to_d_row(Begins at: 335, Ends at:338)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:52:00 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
