[GRASS-QA] GRASS QA: glynn |color.c | 6 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 12:09:24 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.labels/color.c
Function
RGBA_has_color(Begins at: 78, Ends at:84)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
set_color_from_RGBA(Begins at: 88, Ends at:98)
CalledNBR: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
set_RGBA_from_components(Begins at: 23, Ends at:32)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a WARNING |
metrics are OK
set_RGBA_from_str(Begins at: 50, Ends at:69)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 20 | | OK | 20 |
metrics are OK
unset_RGBA(Begins at: 72, Ends at:75)
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
set_color_from_RGBA set_RGBA_from_components set_RGBA_from_components set_RGBA_from_str set_RGBA_from_str
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.labels/color.c clones of set_color_from_RGBA are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.paint.labels/color.c set_color_from_RGBA
/var/project-manager/grass/grassSVN/grass/trunk/display/d.paint.labels/color.c set_color_from_RGBA
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.labels/color.c clones of set_RGBA_from_components are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.paint.labels/color.c set_RGBA_from_components
/var/project-manager/grass/grassSVN/grass/trunk/display/d.paint.labels/color.c set_RGBA_from_components
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.labels/color.c clones of set_RGBA_from_str are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.paint.labels/color.c set_RGBA_from_str
/var/project-manager/grass/grassSVN/grass/trunk/display/d.paint.labels/color.c set_RGBA_from_str
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:14:46 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
