[GRASS-QA] GRASS QA: glynn |Color.c Poly.c Text.c | 8 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 12:11:45 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/cairodriver/Color.c
Function
Cairo_color(Begins at: 7, Ends at:23)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
Cairo_lookup_color(Begins at: 25, Ends at:30)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a WARNING |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Color.c clones of Cairo_color are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Color.c Cairo_color
File :grass/trunk/lib/cairodriver/Poly.c
Function
Cairo_Polydots(Begins at: 28, Ends at:36)
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
Cairo_Polygon(Begins at: 12, Ends at:18)
CalledNBR: | 3 | | OK | 3 |
LOC: | 7 | | OK | 7 |
metrics are OK
Cairo_Polyline(Begins at: 20, Ends at:26)
metrics are OK
do_polygon(Begins at: 3, Ends at:10)
LOC: | 8 | | OK | 8 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/cairodriver/Text.c
Function
Cairo_draw_text(Begins at: 84, Ends at:99)
CalledNBR: | 5 | | OK | 5 |
LOC: | 16 | | OK | 16 |
metrics are OK
Cairo_font_info(Begins at: 251, Ends at:255)
ParamNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
metrics are OK
Cairo_font_list(Begins at: 245, Ends at:249)
metrics are OK
Cairo_set_encoding(Begins at: 217, Ends at:223)
metrics are OK
Cairo_set_font(Begins at: 205, Ends at:215)
CalledNBR: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
Cairo_text_box(Begins at: 101, Ends at:119)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 19 | | OK | 19 |
metrics are OK
convert(Begins at: 13, Ends at:66)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 54 | * | WARNING | 54 |
metrics are OK
font_list_toy(Begins at: 225, Ends at:243)
metrics are OK
is_toy_font(Begins at: 194, Ends at:203)
Complexity: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
set_font_fc(Begins at: 151, Ends at:174)
LOC: | 24 | | OK | 24 |
metrics are OK
set_font_toy(Begins at: 121, Ends at:147)
CalledNBR: | 7 | | OK | 7 |
LOC: | 27 | | OK | 27 |
metrics are OK
set_matrix(Begins at: 68, Ends at:82)
LOC: | 15 | | OK | 15 |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
which_item GS_setall_drawmode find_rule GS_setall_drawmode which_item GS_setall_drawmode
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Text.c clones of is_toy_font are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.colors/main.c find_rule
/var/project-manager/grass/grassSVN/grass/trunk/display/d.save/main.c which_item
/var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/GS2.c GS_setall_drawmode
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.colors/main.c find_rule
/tmp/grassSVN/grass/trunk/lib/ogsf/GS2.c GS_setall_drawmode
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.save/main.c which_item
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/ogsf/GS2.c GS_setall_drawmode
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:17:07 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
