[GRASS-QA] GRASS QA: martinl |write.c | 3 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 12:49:24 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/Vlib/write.c
Function
delete_dummy(Begins at: 36, Ends at:41)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a OK |
metrics are OK
format(Begins at: 44, Ends at:48)
LOC: | 5 | | OK | 5 |
metrics are OK
rewrite_dummy(Begins at: 30, Ends at:35)
metrics are OK
Vect_delete_line(Begins at: 205, Ends at:236)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 32 | | OK | 32 |
metrics are OK
Vect_rewrite_line(Begins at: 145, Ends at:171)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a WARNING |
metrics are OK
Vect_write_line(Begins at: 99, Ends at:125)
ParamNBR: | 4 | * | WARNING | 4 |
metrics are OK
write_dummy(Begins at: 24, Ends at:29)
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
Vect_rewrite_line Vect_write_line
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/write.c clones of Vect_delete_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write.c Vect_delete_line
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/write.c clones of Vect_rewrite_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write.c Vect_rewrite_line
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/write.c clones of Vect_write_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write.c Vect_write_line
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:54:46 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
