[GRASS-QA] GRASS QA: hamish |main.c | 5 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 13:14:24 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.in.xyz/main.c
          Class
node(Begins at: 28, Ends at:32)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
add_node(Begins at: 55, Ends at:90)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      36 |       |           OK |        36 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 94, Ends at:1066)
Complexity:   |     147 |   *** |      MONSTER |       147 |
CalledNBR:    |     286 |   *** |      MONSTER |       286 |
LOC:          |     973 |   *** |      MONSTER |       973 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
new_node(Begins at: 40, Ends at:50)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
scan_bounds(Begins at: 1070, Ends at:1188)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
  add_node  new_node  new_node  scan_bounds
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.xyz/main.c clones of add_node are:
          /tmp/grassSVN/grass/trunk/raster/r.in.xyz/main.c  add_node
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.xyz/main.c  add_node
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.xyz/main.c clones of new_node are:
          /tmp/grassSVN/grass/trunk/raster/r.in.xyz/main.c  new_node
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.xyz/main.c  new_node
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.xyz/main.c clones of scan_bounds are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.xyz/main.c  scan_bounds
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 13:19:46 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
