[GRASS-QA] GRASS QA: hamish |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 13:16:36 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.in.xyz/main.c
Class
node(Begins at: 28, Ends at:32)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
add_node(Begins at: 55, Ends at:90)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 94, Ends at:1064)
Complexity: | 147 | *** | MONSTER | 147 |
CalledNBR: | 286 | *** | MONSTER | 286 |
LOC: | 971 | *** | MONSTER | 968 |
Conclusion: | this function is a MONSTER |
metrics are OK
new_node(Begins at: 40, Ends at:50)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
metrics are OK
scan_bounds(Begins at: 1068, Ends at:1187)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
LOC: | 120 | ** | BABY-MONSTER | 119 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 13:21:58 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
