[GRASS-QA] GRASS QA: glynn |main.c raster.h cairodriver.h Color.c
...| 25 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 13:30:25 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.info/main.c
Function
main(Begins at: 22, Ends at:127)
| New Metrics |Old Metrics|
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 52 | *** | MONSTER | 52 |
LOC: | 106 | ** | BABY-MONSTER | 106 |
Conclusion: | this function is a MONSTER |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/include/raster.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/cairodriver/cairodriver.h
File :grass/trunk/lib/cairodriver/Color.c
Function
Cairo_color(Begins at: 7, Ends at:23)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
Cairo_lookup_color(Begins at: 25, Ends at:30)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a WARNING |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Color.c clones of Cairo_color are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Color.c Cairo_color
File :grass/trunk/lib/cairodriver/Driver.c
Function
Cairo_Driver(Begins at: 22, Ends at:57)
CalledNBR: | 0 | | OK | 0 |
LOC: | 36 | | OK | 36 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
HTML_Driver PNG_Driver
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Driver.c clones of Cairo_Driver are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Driver.c PS_Driver
/var/project-manager/grass/grassSVN/grass/trunk/lib/htmldriver/Driver.c HTML_Driver
/var/project-manager/grass/grassSVN/grass/trunk/lib/pngdriver/Driver.c PNG_Driver
File :grass/trunk/lib/driver/Box.c
Function
COM_Box_abs(Begins at: 4, Ends at:23)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 20 | | OK | 20 |
metrics are OK
COM_Box_rel(Begins at: 25, Ends at:28)
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/driver/Box.c clones of COM_Box_abs are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/driver/Box.c COM_Box_abs
File :grass/trunk/lib/driver/Color.c
Function
COM_Color_RGB(Begins at: 19, Ends at:22)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
COM_Standard_color(Begins at: 24, Ends at:33)
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
DRV_color(Begins at: 12, Ends at:16)
LOC: | 5 | | OK | 5 |
metrics are OK
DRV_lookup_color(Begins at: 5, Ends at:10)
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
COM_Standard_color login_filename open_raster
In /var/project-manager/grass/grassSVN/grass/trunk/lib/driver/Color.c clones of COM_Standard_color are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_base/login.c login_filename
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/driver/Color.c COM_Standard_color
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/login.c login_filename
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r.univar_main.c open_raster
File :grass/trunk/lib/driver/driver.h
Class
driver(Begins at: 25, Ends at:36)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 9 | 0 | 36 |
|OLD Metrics | 1 | 0 | 0 | 9 | 0 | 36 |
Clone analysis:
File :grass/trunk/lib/driver/Erase.c
Function
COM_Erase(Begins at: 4, Ends at:19)
CalledNBR: | 5 | | OK | 5 |
LOC: | 16 | | OK | 16 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/driver/init.c
Function
LIB_init(Begins at: 44, Ends at:65)
LOC: | 22 | | OK | 22 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/driver/Returns.c
Function
COM_Number_of_colors(Begins at: 24, Ends at:27)
metrics are OK
COM_Screen_bot(Begins at: 14, Ends at:17)
metrics are OK
COM_Screen_left(Begins at: 4, Ends at:7)
metrics are OK
COM_Screen_rite(Begins at: 9, Ends at:12)
metrics are OK
COM_Screen_top(Begins at: 19, Ends at:22)
metrics are OK
Clone analysis:
File :grass/trunk/lib/htmldriver/Box.c
File :grass/trunk/lib/htmldriver/Driver.c
Function
HTML_Driver(Begins at: 20, Ends at:55)
metrics are OK
Clone analysis:
PNG_Driver PS_Driver
In /var/project-manager/grass/grassSVN/grass/trunk/lib/htmldriver/Driver.c clones of HTML_Driver are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Driver.c Cairo_Driver
File :grass/trunk/lib/htmldriver/Graph_Set.c
Function
HTML_Graph_set(Begins at: 35, Ends at:146)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 112 | ** | BABY-MONSTER | 112 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
Clone analysis:
File :grass/trunk/lib/htmldriver/htmlmap.h
Class
MapPoly(Begins at: 23, Ends at:30)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
File :grass/trunk/lib/pngdriver/Color.c
Function
PNG_color(Begins at: 12, Ends at:28)
Complexity: | 3 | | OK | 3 |
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/pngdriver/Color.c clones of PNG_color are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/pngdriver/Color.c PNG_color
File :grass/trunk/lib/pngdriver/Color_table.c
Function
get_color(Begins at: 124, Ends at:128)
metrics are OK
get_color_indexed(Begins at: 90, Ends at:96)
LOC: | 7 | | OK | 7 |
metrics are OK
get_color_rgb(Begins at: 85, Ends at:88)
metrics are OK
get_pixel(Begins at: 116, Ends at:122)
ParamNBR: | 5 | * | WARNING | 5 |
metrics are OK
get_pixel_indexed(Begins at: 106, Ends at:113)
LOC: | 8 | | OK | 8 |
metrics are OK
get_pixel_rgb(Begins at: 98, Ends at:104)
metrics are OK
init_colors_indexed(Begins at: 38, Ends at:75)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 38 | | OK | 38 |
metrics are OK
init_colors_rgb(Begins at: 20, Ends at:36)
metrics are OK
init_color_table(Begins at: 77, Ends at:83)
metrics are OK
PNG_lookup_color(Begins at: 130, Ends at:134)
metrics are OK
set_color(Begins at: 12, Ends at:18)
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
init_colors_rgb
In /var/project-manager/grass/grassSVN/grass/trunk/lib/pngdriver/Color_table.c clones of init_colors_indexed are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/pngdriver/Color_table.c init_colors_indexed
In /var/project-manager/grass/grassSVN/grass/trunk/lib/pngdriver/Color_table.c clones of init_colors_rgb are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/pngdriver/Color_table.c init_colors_rgb
File :grass/trunk/lib/pngdriver/Driver.c
Function
PNG_Driver(Begins at: 22, Ends at:57)
metrics are OK
Clone analysis:
HTML_Driver PS_Driver
In /var/project-manager/grass/grassSVN/grass/trunk/lib/pngdriver/Driver.c clones of PNG_Driver are:
File :grass/trunk/lib/pngdriver/pngdriver.h
File :grass/trunk/lib/psdriver/Color.c
Function
PS_color(Begins at: 5, Ends at:21)
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Color.c clones of PS_color are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Color.c PS_color
File :grass/trunk/lib/psdriver/Color_table.c
Function
get_color_gray(Begins at: 19, Ends at:22)
metrics are OK
get_color_rgb(Begins at: 14, Ends at:17)
metrics are OK
init_color_table(Begins at: 9, Ends at:12)
metrics are OK
PS_lookup_color(Begins at: 24, Ends at:28)
metrics are OK
Clone analysis:
File :grass/trunk/lib/psdriver/Driver.c
Function
PS_Driver(Begins at: 22, Ends at:57)
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Driver.c clones of PS_Driver are:
File :grass/trunk/lib/psdriver/Graph_set.c
Class
paper(Begins at: 33, Ends at:38)
Function
get_paper(Begins at: 127, Ends at:170)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 44 | * | WARNING | 44 |
metrics are OK
in2pt(Begins at: 114, Ends at:117)
metrics are OK
output(Begins at: 224, Ends at:231)
metrics are OK
PS_Graph_set(Begins at: 172, Ends at:222)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 51 | * | WARNING | 51 |
metrics are OK
swap(Begins at: 119, Ends at:125)
metrics are OK
write_prolog(Begins at: 53, Ends at:95)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 43 | * | WARNING | 43 |
metrics are OK
write_setup(Begins at: 97, Ends at:112)
CalledNBR: | 7 | | OK | 7 |
metrics are OK
Clone analysis:
write_prolog write_setup
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of get_paper are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c get_paper
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of write_prolog are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c write_prolog
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of write_setup are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c write_setup
File :grass/trunk/lib/psdriver/psdriver.h
File :grass/trunk/lib/raster/raster.c
Function
init(Begins at: 25, Ends at:40)
CalledNBR: | 8 | | OK | 8 |
metrics are OK
R_begin_scaled_raster(Begins at: 540, Ends at:543)
metrics are OK
R_bitmap(Begins at: 557, Ends at:560)
metrics are OK
R_box_abs(Begins at: 413, Ends at:416)
metrics are OK
R_box_rel(Begins at: 431, Ends at:434)
metrics are OK
R_close_driver(Begins at: 68, Ends at:77)
CalledNBR: | 4 | | OK | 4 |
metrics are OK
R_cont_abs(Begins at: 253, Ends at:256)
metrics are OK
R_cont_rel(Begins at: 275, Ends at:278)
metrics are OK
R_encoding(Begins at: 525, Ends at:528)
metrics are OK
R_end_scaled_raster(Begins at: 552, Ends at:555)
metrics are OK
R_erase(Begins at: 200, Ends at:203)
metrics are OK
R_flush(Begins at: 63, Ends at:66)
metrics are OK
R_font(Begins at: 520, Ends at:523)
metrics are OK
R_font_info(Begins at: 535, Ends at:538)
metrics are OK
R_font_list(Begins at: 530, Ends at:533)
metrics are OK
R_get_num_colors(Begins at: 136, Ends at:139)
metrics are OK
R_get_text_box(Begins at: 506, Ends at:509)
metrics are OK
R_line_width(Begins at: 186, Ends at:189)
metrics are OK
R_move_abs(Begins at: 216, Ends at:219)
metrics are OK
R_move_rel(Begins at: 236, Ends at:239)
metrics are OK
R_open_driver(Begins at: 42, Ends at:61)
metrics are OK
R_polydots_abs(Begins at: 293, Ends at:296)
metrics are OK
R_polydots_rel(Begins at: 313, Ends at:316)
metrics are OK
R_polygon_abs(Begins at: 374, Ends at:377)
metrics are OK
R_polygon_rel(Begins at: 394, Ends at:397)
metrics are OK
R_polyline_abs(Begins at: 334, Ends at:337)
metrics are OK
R_polyline_rel(Begins at: 356, Ends at:359)
metrics are OK
R_RGB_color(Begins at: 172, Ends at:175)
metrics are OK
R_scaled_raster(Begins at: 545, Ends at:550)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
metrics are OK
R_screen_bot(Begins at: 116, Ends at:119)
metrics are OK
R_screen_left(Begins at: 88, Ends at:91)
metrics are OK
R_screen_rite(Begins at: 102, Ends at:105)
metrics are OK
R_screen_top(Begins at: 131, Ends at:134)
metrics are OK
R_set_window(Begins at: 469, Ends at:472)
metrics are OK
R_standard_color(Begins at: 153, Ends at:156)
metrics are OK
R_text(Begins at: 484, Ends at:487)
metrics are OK
R_text_rotation(Begins at: 451, Ends at:454)
metrics are OK
R_text_size(Begins at: 446, Ends at:449)
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 13:35:48 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
