[GRASS-QA] GRASS QA: martinl |digit.h line.cpp vertex.cpp | no clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 14:44:03 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
Class
Digit(Begins at: 9, Ends at:92)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
|OLD Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
Class
_settings(Begins at: 32, Ends at:34)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
action_meta(Begins at: 22, Ends at:29)
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp
Class
Digit(Begins at: -9999, Ends at:-9999)
|NEW Metrics | 1 | 0 | 112 | 402 | 0 | 91 |
|OLD Metrics | 1 | 0 | 112 | 402 | 0 | 91 |
Method
AddLine(Begins at: 38, Ends at:182)
| New Metrics |Old Metrics|
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 7 | | OK | 7 |
CalledNBR: | 41 | ** | BABY-MONSTER | 41 |
LOC: | 145 | ** | BABY-MONSTER | 145 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
BreakLines(Begins at: 614, Ends at:651)
Complexity: | 8 | ** | BABY-MONSTER | 8 |
ParamNBR: | 0 | ** | BABY-MONSTER | 0 |
CalledNBR: | 9 | *** | MONSTER | 9 |
LOC: | 38 | *** | MONSTER | 38 |
Conclusion: | this function is a MONSTER |
metrics are OK
ConnectLines(Begins at: 681, Ends at:712)
Complexity: | 5 | * | WARNING | 5 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 32 | | OK | 32 |
Conclusion: | this function is a WARNING |
metrics are OK
CopyLines(Begins at: 752, Ends at:807)
Complexity: | 9 | | OK | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 56 | | OK | 56 |
Conclusion: | this function is a OK |
metrics are OK
DeleteLines(Begins at: 338, Ends at:461)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 27 | * | WARNING | 27 |
LOC: | 124 | * | WARNING | 124 |
metrics are OK
FlipLines(Begins at: 532, Ends at:560)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 29 | | OK | 29 |
metrics are OK
MergeLines(Begins at: 568, Ends at:604)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 37 | | OK | 37 |
metrics are OK
MoveLines(Begins at: 475, Ends at:524)
ParamNBR: | 6 | | OK | 6 |
CalledNBR: | 8 | * | WARNING | 8 |
LOC: | 50 | | OK | 50 |
metrics are OK
OpenBackgroundVectorMap(Begins at: 819, Ends at:857)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 39 | | OK | 39 |
metrics are OK
RewriteLine(Begins at: 196, Ends at:283)
Complexity: | 13 | | OK | 13 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 20 | | OK | 20 |
LOC: | 88 | | OK | 88 |
metrics are OK
SnapLines(Begins at: 663, Ends at:673)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 11 | | OK | 11 |
metrics are OK
SplitLine(Begins at: 296, Ends at:328)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
LOC: | 33 | | OK | 33 |
metrics are OK
TypeConvLines(Begins at: 869, Ends at:901)
CalledNBR: | 7 | | OK | 7 |
LOC: | 33 | * | WARNING | 33 |
metrics are OK
ZBulkLabeling(Begins at: 728, Ends at:741)
Complexity: | 2 | ** | BABY-MONSTER | 2 |
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 14 | * | WARNING | 14 |
metrics are OK
Clone analysis:
File :grass/branches/develbranch_6/gui/wxpython/vdigit/vertex.cpp
Class
|NEW Metrics | 1 | 0 | 12 | 58 | 0 | 1 |
|OLD Metrics | 1 | 0 | 12 | 58 | 0 | 1 |
Method
ModifyLineVertex(Begins at: 108, Ends at:146)
CalledNBR: | 11 | * | WARNING | 11 |
metrics are OK
MoveVertex(Begins at: 37, Ends at:93)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 10 | *** | MONSTER | 10 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 57 | * | WARNING | 57 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 14:49:26 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
