[GRASS-QA] GRASS QA: glynn |gisdefs.h ls.c | 3 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 15:06:36 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/gis/ls.c
Function
cmp_names(Begins at: 32, Ends at:38)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
G_ls(Begins at: 94, Ends at:107)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 14 | | OK | 14 |
metrics are OK
G_ls_format(Begins at: 124, Ends at:185)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 62 | * | WARNING | 62 |
Conclusion: | this function is a WARNING |
metrics are OK
G__ls(Begins at: 56, Ends at:80)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 25 | | OK | 25 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
G_ls_format G__ls
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/ls.c clones of G_ls are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/ls.c G_ls
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/ls.c clones of G_ls_format are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/ls.c G_ls_format
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/ls.c clones of G__ls are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/ls.c G__ls
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 15:12:00 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
