[GRASS-QA] GRASS QA: glynn |gisdefs.h global.h join.c ls.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 15:08:58 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/general/g.mlist/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/general/g.mlist/global.h
File :grass/trunk/general/g.mlist/join.c
File :grass/trunk/general/g.mlist/ls.c
File :grass/trunk/general/g.mlist/main.c
File :grass/trunk/general/g.mlist/read_list.c
File :grass/trunk/general/g.mremove/do_remove.c
File :grass/trunk/general/g.mremove/gisdefs.h
File :grass/trunk/general/g.mremove/global.h
File :grass/trunk/general/g.mremove/join.c
File :grass/trunk/general/g.mremove/ls.c
File :grass/trunk/general/g.mremove/main.c
File :grass/trunk/general/g.mremove/read_list.c
File :grass/trunk/general/g.mremove/sighold.c
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 15:14:22 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
