[GRASS-QA] GRASS QA: hamish |test.c | 24 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Sep 10 20:50:03 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/swig/python/NumPtr/src/test.c
Function
test1(Begins at: 1, Ends at:8)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
test2(Begins at: 10, Ends at:19)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a WARNING |
metrics are OK
test3(Begins at: 21, Ends at:32)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 12 | | OK | 12 |
metrics are OK
testd1(Begins at: 34, Ends at:41)
metrics are OK
testd2(Begins at: 43, Ends at:52)
metrics are OK
testd3(Begins at: 54, Ends at:65)
metrics are OK
testf1(Begins at: 67, Ends at:74)
metrics are OK
testf2(Begins at: 76, Ends at:85)
metrics are OK
testf3(Begins at: 87, Ends at:98)
metrics are OK
testi1(Begins at: 100, Ends at:107)
metrics are OK
testi2(Begins at: 109, Ends at:118)
metrics are OK
testi3(Begins at: 120, Ends at:131)
metrics are OK
Clone analysis:
This file has 24 potentially cloned functions:
testf2 testi2 testd3 testf3 testi3 test2 testf2 testi2 test3 testf3 testi3 test2 testd2 testi2 test3 testd3 testi3 test2 testd2 testf2 test3 testd3 testf3
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of test2 are:
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testd2
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testf2
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testi2
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of test3 are:
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testd3
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testf3
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c testi3
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testd2 are:
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c test2
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testd3 are:
/var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c test3
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testf2 are:
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testf3 are:
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testi2 are:
In /var/project-manager/grass/grassSVN/grass/trunk/swig/python/NumPtr/src/test.c clones of testi3 are:
____________________________________________
Threshold GRASS6 key metrics values at Wed Sep 10 20:56:34 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
