[GRASS-QA] GRASS QA: hamish |window_map.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Sep 15 10:18:27 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/gis/window_map.c
          Function
G_adjust_easting(Begins at: 173, Ends at:182)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_adjust_east_longitude(Begins at: 148, Ends at:156)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
G_col_to_easting(Begins at: 242, Ends at:245)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
G_easting_to_col(Begins at: 197, Ends at:202)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
G_northing_to_row(Begins at: 128, Ends at:131)
metrics are OK
G_row_repeat_nomask(Begins at: 343, Ends at:373)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
G_row_to_northing(Begins at: 222, Ends at:225)
metrics are OK
G_window_cols(Begins at: 305, Ends at:310)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
G_window_rows(Begins at: 272, Ends at:277)
metrics are OK
G__create_window_mapping(Begins at: 36, Ends at:113)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      78 |     * |      WARNING |        78 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
G__init_window(Begins at: 319, Ends at:327)
Complexity:   |       2 |       |           OK |         2 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Mon Sep 15 10:25:57 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
