[GRASS-QA] GRASS QA: hamish |window_map.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Mon Sep 15 10:21:02 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/window_map.c
Function
G_adjust_easting(Begins at: 173, Ends at:182)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
G_adjust_east_longitude(Begins at: 148, Ends at:156)
CalledNBR: | 0 | | OK | 0 |
LOC: | 9 | | OK | 9 |
metrics are OK
G_col_to_easting(Begins at: 242, Ends at:245)
Complexity: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
G_easting_to_col(Begins at: 197, Ends at:202)
LOC: | 6 | | OK | 6 |
metrics are OK
G_northing_to_row(Begins at: 128, Ends at:131)
metrics are OK
G_row_repeat_nomask(Begins at: 343, Ends at:373)
Complexity: | 5 | | OK | 5 |
LOC: | 31 | | OK | 31 |
metrics are OK
G_row_to_northing(Begins at: 222, Ends at:225)
metrics are OK
G_window_cols(Begins at: 305, Ends at:310)
ParamNBR: | 1 | | OK | 1 |
metrics are OK
G_window_rows(Begins at: 272, Ends at:277)
metrics are OK
G__create_window_mapping(Begins at: 36, Ends at:113)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 78 | * | WARNING | 78 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
G__init_window(Begins at: 319, Ends at:327)
Complexity: | 2 | | OK | 2 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Mon Sep 15 10:28:32 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
