[GRASS-QA] GRASS QA: neteler |local_proto.h main.c random.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 23 20:02:01 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.random/local_proto.h
          Class
RASTER_MAP_PTR(Begins at: 13, Ends at:17)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
RASTER_PTR(Begins at: 5, Ends at:11)
          Class
rr_state(Begins at: 24, Ends at:32)
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.random/main.c
          Function
has_percent(Begins at: 175, Ends at:182)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 30, Ends at:172)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      40 |   *** |      MONSTER |        40 |
LOC:          |     143 |   *** |      MONSTER |       143 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/raster/r.random/random.c
          Function
cell_as_dbl(Begins at: 282, Ends at:294)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
cpvalue(Begins at: 265, Ends at:279)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
execute_random(Begins at: 16, Ends at:262)
Complexity:   |      48 |   *** |      MONSTER |        48 |
CalledNBR:    |      97 |   *** |      MONSTER |        97 |
LOC:          |     247 |   *** |      MONSTER |       247 |
is_null_value(Begins at: 313, Ends at:328)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
set_to_null(Begins at: 297, Ends at:310)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 23 20:13:08 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
