[GRASS-QA] GRASS QA: mlennert |dbfexe.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Sun Apr 26 01:38:16 EDT 2009
Hello mlennert,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c
Function
cmp_row_asc(Begins at: 469, Ends at:506)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 38 | | OK | 38 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
cmp_row_desc(Begins at: 508, Ends at:513)
Complexity: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a OK |
metrics are OK
eval_node(Begins at: 644, Ends at:939)
Complexity: | 72 | *** | MONSTER | 72 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 296 | *** | MONSTER | 296 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
eval_node_type(Begins at: 988, Ends at:1138)
Complexity: | 44 | *** | MONSTER | 44 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 151 | *** | MONSTER | 151 |
eval_val(Begins at: 346, Ends at:406)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 61 | * | WARNING | 61 |
at least 4 values are close to an outlier please consider revising code!
execute(Begins at: 45, Ends at:317)
Complexity: | 42 | *** | MONSTER | 42 |
CalledNBR: | 61 | *** | MONSTER | 61 |
LOC: | 273 | *** | MONSTER | 273 |
get_col_def(Begins at: 320, Ends at:344)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 25 | | OK | 25 |
at least 2 values are close to an outlier please consider revising code!
sel(Begins at: 517, Ends at:629)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 113 | ** | BABY-MONSTER | 113 |
Conclusion: | this function is a BABY-MONSTER |
set_val(Begins at: 408, Ends at:464)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 57 | * | WARNING | 57 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sun Apr 26 01:49:54 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
