[GRASS-QA] GRASS QA: glynn |put_cellhd.c quant_rw.c range.c | 4
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Apr 30 12:51:57 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/put_cellhd.c
Function
G_put_cellhd(Begins at: 19, Ends at:35)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/quant_rw.c
Function
G_quantize_fp_map(Begins at: 113, Ends at:133)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 21 | | OK | 21 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
G_quantize_fp_map_range(Begins at: 159, Ends at:176)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
G_read_quant(Begins at: 245, Ends at:249)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
G_round_fp_map(Begins at: 81, Ends at:96)
LOC: | 16 | | OK | 16 |
metrics are OK
G_truncate_fp_map(Begins at: 64, Ends at:79)
metrics are OK
G_write_quant(Begins at: 198, Ends at:221)
LOC: | 24 | | OK | 24 |
Clone analysis:
File :grass/trunk/lib/gis/range.c
Function
G__remove_fp_range(Begins at: 95, Ends at:100)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
G__row_update_range(Begins at: 498, Ends at:520)
Complexity: | 6 | | OK | 6 |
LOC: | 23 | | OK | 23 |
G_construct_default_range(Begins at: 112, Ends at:118)
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 7 | | OK | 7 |
G_get_fp_range_min_max(Begins at: 667, Ends at:687)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | | OK | 3 |
metrics are OK
G_get_range_min_max(Begins at: 608, Ends at:627)
LOC: | 20 | | OK | 20 |
metrics are OK
G_init_fp_range(Begins at: 642, Ends at:649)
Complexity: | 1 | * | WARNING | 1 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 8 | * | WARNING | 8 |
at least 4 values are close to an outlier please consider revising code!
G_init_range(Begins at: 579, Ends at:586)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 2 | ** | BABY-MONSTER | 2 |
G_read_fp_range(Begins at: 139, Ends at:195)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 18 | | OK | 18 |
LOC: | 57 | | OK | 57 |
at least 2 values are close to an outlier please consider revising code!
G_read_range(Begins at: 226, Ends at:311)
Complexity: | 15 | | OK | 15 |
CalledNBR: | 23 | | OK | 23 |
LOC: | 86 | | OK | 86 |
G_row_update_fp_range(Begins at: 524, Ends at:562)
Complexity: | 10 | | OK | 10 |
ParamNBR: | 4 | | OK | 4 |
LOC: | 39 | | OK | 39 |
metrics are OK
G_row_update_range(Begins at: 489, Ends at:494)
metrics are OK
G_update_fp_range(Begins at: 456, Ends at:471)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 1 | * | WARNING | 1 |
G_update_range(Begins at: 436, Ends at:452)
G_write_fp_range(Begins at: 380, Ends at:416)
CalledNBR: | 13 | | OK | 13 |
LOC: | 37 | | OK | 37 |
metrics are OK
G_write_range(Begins at: 334, Ends at:363)
Complexity: | 4 | * | WARNING | 4 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 30 | | OK | 30 |
Clone analysis:
This file has 4 potentially cloned functions:
G_get_fp_range_min_max G_update_range G_update_fp_range
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c clones of G_get_fp_range_min_max are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c G_get_range_min_max
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c clones of G_get_range_min_max are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c G_get_fp_range_min_max
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c clones of G_update_fp_range are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c G_update_range
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c clones of G_update_range are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/range.c G_update_fp_range
____________________________________________
Threshold grass key metrics values at Thu Apr 30 13:04:32 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
