[GRASS-QA] GRASS QA: glynn |stats.h c_ave.c c_count.c c_divr.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Apr 30 12:52:56 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/stats.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/stats/c_ave.c
Function
c_ave(Begins at: 3, Ends at:24)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/stats/c_count.c
Function
c_count(Begins at: 3, Ends at:15)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 13 | | OK | 13 |
Clone analysis:
File :grass/trunk/lib/stats/c_divr.c
Function
c_divr(Begins at: 4, Ends at:29)
LOC: | 26 | | OK | 26 |
Clone analysis:
File :grass/trunk/lib/stats/c_intr.c
Function
c_intr(Begins at: 4, Ends at:35)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 32 | | OK | 32 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/stats/c_kurt.c
Function
c_kurt(Begins at: 3, Ends at:43)
LOC: | 41 | | OK | 41 |
Clone analysis:
File :grass/trunk/lib/stats/c_max.c
Function
c_max(Begins at: 3, Ends at:22)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 20 | | OK | 20 |
Clone analysis:
File :grass/trunk/lib/stats/c_maxx.c
Function
c_maxx(Begins at: 3, Ends at:25)
CalledNBR: | 6 | | OK | 6 |
LOC: | 23 | | OK | 23 |
Clone analysis:
File :grass/trunk/lib/stats/c_median.c
Function
c_median(Begins at: 4, Ends at:12)
Complexity: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
Clone analysis:
File :grass/trunk/lib/stats/c_min.c
Function
c_min(Begins at: 3, Ends at:22)
Clone analysis:
File :grass/trunk/lib/stats/c_minx.c
Function
c_minx(Begins at: 4, Ends at:26)
Clone analysis:
File :grass/trunk/lib/stats/c_mode.c
Function
c_mode(Begins at: 4, Ends at:35)
Clone analysis:
File :grass/trunk/lib/stats/c_percentile.c
Function
c_perc90(Begins at: 36, Ends at:39)
Complexity: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
c_quart1(Begins at: 26, Ends at:29)
c_quart3(Begins at: 31, Ends at:34)
percentile(Begins at: 5, Ends at:24)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 4 | | OK | 4 |
Clone analysis:
File :grass/trunk/lib/stats/c_range.c
Function
c_range(Begins at: 3, Ends at:26)
CalledNBR: | 8 | | OK | 8 |
LOC: | 24 | | OK | 24 |
Clone analysis:
File :grass/trunk/lib/stats/c_reg.c
Function
c_reg_c(Begins at: 81, Ends at:84)
c_reg_m(Begins at: 76, Ends at:79)
c_reg_r2(Begins at: 86, Ends at:89)
regression(Begins at: 7, Ends at:74)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 68 | * | WARNING | 68 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/lib/stats/c_skew.c
Function
c_skew(Begins at: 4, Ends at:44)
Clone analysis:
File :grass/trunk/lib/stats/c_stddev.c
Function
c_stddev(Begins at: 5, Ends at:15)
LOC: | 11 | | OK | 11 |
Clone analysis:
File :grass/trunk/lib/stats/c_sum.c
Function
c_sum(Begins at: 3, Ends at:24)
Clone analysis:
File :grass/trunk/lib/stats/c_var.c
Function
c_var(Begins at: 3, Ends at:40)
LOC: | 38 | | OK | 38 |
Clone analysis:
File :grass/trunk/raster/r.neighbors/main.c
Class
menu(Begins at: 32, Ends at:41)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
main(Begins at: 64, Ends at:316)
Complexity: | 30 | *** | MONSTER | 30 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 91 | *** | MONSTER | 91 |
LOC: | 253 | *** | MONSTER | 253 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :grass/trunk/raster/r.resamp.stats/main.c
Function
build_method_list(Begins at: 44, Ends at:61)
ParamNBR: | 1 | | OK | 1 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a OK |
metrics are OK
find_method(Begins at: 63, Ends at:72)
LOC: | 10 | | OK | 10 |
metrics are OK
main(Begins at: 238, Ends at:378)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 66 | *** | MONSTER | 66 |
LOC: | 141 | *** | MONSTER | 141 |
resamp_unweighted(Begins at: 82, Ends at:150)
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 69 | * | WARNING | 69 |
at least 3 values are close to an outlier please consider revising code!
resamp_weighted(Begins at: 152, Ends at:236)
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 85 | * | WARNING | 85 |
Clone analysis:
File :grass/trunk/raster/r.series/main.c
Class
input(Begins at: 55, Ends at:60)
Class
menu(Begins at: 24, Ends at:53)
Class
output(Begins at: 62, Ends at:68)
Function
build_method_list(Begins at: 70, Ends at:87)
metrics are OK
find_method(Begins at: 89, Ends at:100)
Complexity: | 3 | *** | MONSTER | 3 |
CalledNBR: | 3 | *** | MONSTER | 3 |
LOC: | 12 | *** | MONSTER | 12 |
main(Begins at: 102, Ends at:278)
Complexity: | 23 | | OK | 23 |
CalledNBR: | 57 | | OK | 57 |
LOC: | 177 | | OK | 177 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 30 13:05:31 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
