[GRASS-QA] GRASS QA: mmetz |spindex_rw.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Wed Aug 5 09:37:58 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/spindex_rw.c
Function
dig_Rd_spindx_head(Begins at: 79, Ends at:162)
| New Metrics |Old Metrics|
Complexity: | 14 | ** | BABY-MONSTER | 14 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 84 | * | WARNING | 84 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
dig_Wr_spindx_head(Begins at: 23, Ends at:76)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 54 | * | WARNING | 54 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
dig_dump_spidx(Begins at: 383, Ends at:399)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
dig_read_spidx(Begins at: 356, Ends at:380)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 25 | | OK | 25 |
at least 1 values are close to an outlier please consider revising code!
dig_write_spidx(Begins at: 330, Ends at:353)
LOC: | 24 | | OK | 24 |
rtree_dump_branch(Begins at: 167, Ends at:183)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 3 | | OK | 3 |
rtree_dump_node(Begins at: 186, Ends at:205)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 20 | | OK | 20 |
rtree_read_branch(Begins at: 268, Ends at:302)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 35 | | OK | 35 |
at least 2 values are close to an outlier please consider revising code!
rtree_read_node(Begins at: 305, Ends at:327)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 23 | | OK | 23 |
rtree_write_branch(Begins at: 210, Ends at:237)
CalledNBR: | 5 | | OK | 5 |
LOC: | 28 | | OK | 28 |
rtree_write_node(Begins at: 240, Ends at:263)
Complexity: | 6 | * | WARNING | 6 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 05 09:26:19 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
