[GRASS-QA] GRASS QA: marisn |main.c dbmscap.c misc.c main.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Aug 5 09:45:26 EDT 2009
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/display/d.mon/cmd/main.c
Function
main(Begins at: 35, Ends at:149)
| New Metrics |Old Metrics|
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 42 | *** | MONSTER | 42 |
LOC: | 115 | ** | BABY-MONSTER | 115 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
run(Begins at: 151, Ends at:157)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
Function
add_entry(Begins at: 191, Ends at:219)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 29 | | OK | 29 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
db_copy_dbmscap_entry(Begins at: 67, Ends at:72)
LOC: | 6 | | OK | 6 |
metrics are OK
db_dbmscap_filename(Begins at: 45, Ends at:48)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
db_free_dbmscap(Begins at: 227, Ends at:235)
Complexity: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
db_has_dbms(Begins at: 56, Ends at:59)
metrics are OK
db_read_dbmscap(Begins at: 87, Ends at:189)
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
Conclusion: | this function is a BABY-MONSTER |
dbmscap_filename(Begins at: 20, Ends at:37)
Complexity: | 5 | | OK | 5 |
LOC: | 18 | | OK | 18 |
metrics are OK
Clone analysis:
File :grass/branches/develbranch_6/raster/r.topmodel/misc.c
Function
basin_elevation(Begins at: 67, Ends at:80)
CalledNBR: | 4 | | OK | 4 |
LOC: | 14 | | OK | 14 |
metrics are OK
depressionless(Begins at: 49, Ends at:64)
LOC: | 16 | | OK | 16 |
metrics are OK
gregion(Begins at: 23, Ends at:46)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 24 | | OK | 24 |
run(Begins at: 4, Ends at:20)
LOC: | 17 | | OK | 17 |
metrics are OK
top_index(Begins at: 83, Ends at:108)
CalledNBR: | 8 | | OK | 8 |
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
File :grass/branches/develbranch_6/raster/r.watershed/front/main.c
Function
main(Begins at: 23, Ends at:375)
Complexity: | 29 | *** | MONSTER | 29 |
CalledNBR: | 133 | *** | MONSTER | 133 |
LOC: | 353 | *** | MONSTER | 353 |
write_hist(Begins at: 378, Ends at:393)
Clone analysis:
File :grass/branches/develbranch_6/raster/r.watershed/shed/com_line.c
Function
basin_com_add(Begins at: 479, Ends at:492)
CalledNBR: | 2 | | OK | 2 |
com_add(Begins at: 494, Ends at:503)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 10 | | OK | 10 |
com_line_Gwater(Begins at: 8, Ends at:463)
Complexity: | 76 | *** | MONSTER | 76 |
CalledNBR: | 258 | *** | MONSTER | 258 |
LOC: | 456 | *** | MONSTER | 456 |
com_line_add(Begins at: 465, Ends at:477)
CalledNBR: | 6 | | OK | 6 |
LOC: | 13 | | OK | 13 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 05 09:33:46 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
