[GRASS-QA] GRASS QA: hamish |local_proto.h main.c plot1.c | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Aug 5 11:38:40 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/display/d.vect/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/branches/develbranch_6/display/d.vect/main.c
Function
icon_files(Begins at: 32, Ends at:76)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 45 | * | WARNING | 45 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 78, Ends at:749)
Complexity: | 83 | *** | MONSTER | 83 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 216 | *** | MONSTER | 216 |
LOC: | 672 | *** | MONSTER | 672 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/display/d.vect/plot1.c
Function
local_plot_poly(Begins at: 48, Ends at:69)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 22 | | OK | 22 |
at least 2 values are close to an outlier please consider revising code!
plot1(Begins at: 129, Ends at:530)
Complexity: | 60 | *** | MONSTER | 60 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 94 | *** | MONSTER | 94 |
LOC: | 402 | *** | MONSTER | 402 |
plot_polygon(Begins at: 102, Ends at:124)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 23 | | OK | 23 |
plot_polyline(Begins at: 74, Ends at:97)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 24 | | OK | 24 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 05 11:26:59 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
