[GRASS-QA] GRASS QA: hamish |local_proto.h main.c plot1.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 5 11:45:59 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.vect/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/display/d.vect/main.c
          Function
icon_files(Begins at: 32, Ends at:76)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      45 |     * |      WARNING |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
main(Begins at: 78, Ends at:720)
Complexity:   |      80 |   *** |      MONSTER |        80 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     202 |   *** |      MONSTER |       202 |
LOC:          |     643 |   *** |      MONSTER |       643 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/display/d.vect/plot1.c
          Function
plot1(Begins at: 80, Ends at:479)
Complexity:   |      60 |       |           OK |        60 |
ParamNBR:     |      18 |     * |      WARNING |        18 |
CalledNBR:    |      95 |     * |      WARNING |        95 |
LOC:          |     400 |       |           OK |       400 |
 at least 2 values are close to an outlier please consider revising code!
plot_polygon(Begins at: 62, Ends at:75)
Complexity:   |       5 |   *** |      MONSTER |         5 |
ParamNBR:     |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |      14 |   *** |      MONSTER |        14 |
plot_polyline(Begins at: 44, Ends at:57)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 05 11:34:18 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
