[GRASS-QA] GRASS QA: martinl |c_assign.c c_begin.c c_clear.c c_distinct.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 5 13:44:44 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/cluster/c_assign.c
          Function
I_cluster_assign(Begins at: 4, Ends at:41)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      38 |       |           OK |        38 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/cluster/c_begin.c
          Function
I_cluster_begin(Begins at: 16, Ends at:77)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      62 |     * |      WARNING |        62 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/lib/cluster/c_clear.c
          Function
I_cluster_clear(Begins at: 2, Ends at:19)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_distinct.c
          Function
I_cluster_distinct(Begins at: 3, Ends at:34)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      32 |       |           OK |        32 |
Clone analysis:
          File :grass/trunk/lib/cluster/c_exec.c
          Function
I_cluster_exec(Begins at: 23, Ends at:123)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |     101 |    ** | BABY-MONSTER |       101 |
Clone analysis:
          File :grass/trunk/lib/cluster/c_execmem.c
          Function
I_cluster_exec_allocate(Begins at: 3, Ends at:25)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
I_cluster_exec_free(Begins at: 27, Ends at:47)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      21 |       |           OK |        21 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_means.c
          Function
I_cluster_means(Begins at: 4, Ends at:28)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_merge.c
          Function
I_cluster_merge(Begins at: 3, Ends at:22)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_nclasses.c
          Function
I_cluster_nclasses(Begins at: 3, Ends at:12)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_point.c
          Function
I_cluster_begin_point_set(Begins at: 54, Ends at:57)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
I_cluster_end_point_set(Begins at: 72, Ends at:88)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
I_cluster_point(Begins at: 24, Ends at:52)
LOC:          |      29 |       |           OK |        29 |
metrics are OK
I_cluster_point_part(Begins at: 59, Ends at:70)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      12 |       |           OK |        12 |
all_zero(Begins at: 90, Ends at:98)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
extend(Begins at: 100, Ends at:114)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/cluster/c_reassign.c
          Function
I_cluster_reassign(Begins at: 4, Ends at:74)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
LOC:          |      71 |     * |      WARNING |        71 |
Clone analysis:
          File :grass/trunk/lib/cluster/c_reclass.c
          Function
I_cluster_reclass(Begins at: 3, Ends at:35)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      33 |       |           OK |        33 |
Clone analysis:
          File :grass/trunk/lib/cluster/c_sep.c
          Function
I_cluster_separation(Begins at: 6, Ends at:60)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      55 |     * |      WARNING |        55 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/lib/cluster/c_sig.c
          Function
I_cluster_signatures(Begins at: 2, Ends at:58)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
LOC:          |      57 |     * |      WARNING |        57 |
Clone analysis:
          File :grass/trunk/lib/cluster/c_sum2.c
          Function
I_cluster_sum2(Begins at: 4, Ends at:27)
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 05 13:33:00 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
