[GRASS-QA] GRASS QA: martinl |field.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 5 13:52:18 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/field.c
          Function
Vect_add_dblink(Begins at: 209, Ends at:261)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      53 |     * |      WARNING |        53 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_check_dblink(Begins at: 181, Ends at:193)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_default_field_info(Begins at: 273, Ends at:347)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      75 |     * |      WARNING |        75 |
Vect_get_dblink(Begins at: 360, Ends at:386)
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      27 |       |           OK |        27 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_get_field(Begins at: 400, Ends at:415)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Vect_map_add_dblink(Begins at: 81, Ends at:110)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
Vect_map_check_dblink(Begins at: 167, Ends at:170)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_map_del_dblink(Begins at: 121, Ends at:156)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      36 |       |           OK |        36 |
Vect_new_dblinks_struct(Begins at: 41, Ends at:53)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
Vect_read_dblinks(Begins at: 427, Ends at:657)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      78 |   *** |      MONSTER |        78 |
LOC:          |     231 |   *** |      MONSTER |       231 |
Conclusion:   | this function is a       MONSTER           |
Vect_reset_dblinks(Begins at: 62, Ends at:65)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
Vect_set_db_updated(Begins at: 771, Ends at:778)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Vect_subst_var(Begins at: 718, Ends at:758)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      41 |       |           OK |        41 |
Vect_write_dblinks(Begins at: 667, Ends at:708)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      42 |     * |      WARNING |        42 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 05 13:40:34 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
