[GRASS-QA] GRASS QA: martinl |string.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 5 13:59:46 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/db/dbmi_base/string.c
          Function
db_alloc_string_array(Begins at: 172, Ends at:185)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_append_string(Begins at: 193, Ends at:204)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
db_copy_string(Begins at: 212, Ends at:215)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_double_quote_string(Begins at: 223, Ends at:242)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
db_enlarge_string(Begins at: 111, Ends at:122)
metrics are OK
db_free_string(Begins at: 142, Ends at:147)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
db_free_string_array(Begins at: 155, Ends at:164)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
db_get_string(Begins at: 131, Ends at:134)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
db_init_string(Begins at: 11, Ends at:15)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
db_set_string(Begins at: 33, Ends at:36)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
db_set_string_no_copy(Begins at: 44, Ends at:47)
metrics are OK
db_sizeof_string(Begins at: 55, Ends at:60)
metrics are OK
db_zero_string(Begins at: 68, Ends at:71)
metrics are OK
set_string(Begins at: 79, Ends at:103)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 05 13:48:01 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
