[GRASS-QA] GRASS QA: mmetz |filldir.c main.c resolve.c tinf.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Aug 7 11:33:31 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.drain/filldir.c
Function
build_one_row(Begins at: 33, Ends at:95)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 63 | * | WARNING | 63 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
check(Begins at: 10, Ends at:30)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 21 | | OK | 21 |
filldir(Begins at: 97, Ends at:123)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.drain/main.c
Class
point(Begins at: 60, Ends at:66)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
drain(Begins at: 447, Ends at:504)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 58 | * | WARNING | 58 |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 68, Ends at:445)
Complexity: | 39 | *** | MONSTER | 39 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 127 | *** | MONSTER | 127 |
LOC: | 378 | *** | MONSTER | 378 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :grass/trunk/raster/r.drain/resolve.c
Function
flink(Begins at: 33, Ends at:95)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 9 | *** | MONSTER | 9 |
resolve(Begins at: 97, Ends at:207)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 111 | ** | BABY-MONSTER | 111 |
select_dir(Begins at: 6, Ends at:31)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 26 | | OK | 26 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.drain/tinf.c
Function
advance_band3(Begins at: 373, Ends at:387)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 15 | | OK | 15 |
metrics are OK
bpe_c(Begins at: 121, Ends at:124)
ParamNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
bpe_d(Begins at: 131, Ends at:134)
metrics are OK
bpe_f(Begins at: 126, Ends at:129)
metrics are OK
diff_c(Begins at: 275, Ends at:278)
metrics are OK
diff_d(Begins at: 283, Ends at:286)
metrics are OK
diff_f(Begins at: 279, Ends at:282)
metrics are OK
get_buf_c(Begins at: 231, Ends at:234)
metrics are OK
get_buf_d(Begins at: 241, Ends at:244)
metrics are OK
get_buf_f(Begins at: 236, Ends at:239)
metrics are OK
get_max_c(Begins at: 168, Ends at:176)
LOC: | 9 | | OK | 9 |
metrics are OK
get_max_d(Begins at: 188, Ends at:196)
metrics are OK
get_max_f(Begins at: 178, Ends at:186)
metrics are OK
get_min_c(Begins at: 137, Ends at:145)
metrics are OK
get_min_d(Begins at: 157, Ends at:165)
metrics are OK
get_min_f(Begins at: 147, Ends at:155)
metrics are OK
get_row_c(Begins at: 199, Ends at:202)
at least 1 values are close to an outlier please consider revising code!
get_row_d(Begins at: 209, Ends at:212)
get_row_f(Begins at: 204, Ends at:207)
is_null_c(Begins at: 93, Ends at:96)
metrics are OK
is_null_d(Begins at: 101, Ends at:104)
metrics are OK
is_null_f(Begins at: 97, Ends at:100)
metrics are OK
prod_c(Begins at: 317, Ends at:320)
metrics are OK
prod_d(Begins at: 325, Ends at:328)
metrics are OK
prod_f(Begins at: 321, Ends at:324)
metrics are OK
put_row_c(Begins at: 215, Ends at:218)
metrics are OK
put_row_d(Begins at: 225, Ends at:228)
metrics are OK
put_row_f(Begins at: 220, Ends at:223)
metrics are OK
quot_c(Begins at: 303, Ends at:306)
metrics are OK
quot_d(Begins at: 311, Ends at:314)
metrics are OK
quot_f(Begins at: 307, Ends at:310)
metrics are OK
retreat_band3(Begins at: 391, Ends at:407)
LOC: | 17 | | OK | 17 |
metrics are OK
set_func_pointers(Begins at: 28, Ends at:90)
Complexity: | 5 | | OK | 5 |
set_max_c(Begins at: 261, Ends at:264)
metrics are OK
set_max_d(Begins at: 269, Ends at:272)
metrics are OK
set_max_f(Begins at: 265, Ends at:268)
metrics are OK
set_min_c(Begins at: 247, Ends at:250)
metrics are OK
set_min_d(Begins at: 255, Ends at:258)
metrics are OK
set_min_f(Begins at: 251, Ends at:254)
metrics are OK
set_null_value_c(Begins at: 107, Ends at:110)
metrics are OK
set_null_value_d(Begins at: 115, Ends at:118)
metrics are OK
set_null_value_f(Begins at: 111, Ends at:114)
metrics are OK
slope_c(Begins at: 332, Ends at:343)
LOC: | 12 | | OK | 12 |
slope_d(Begins at: 358, Ends at:369)
slope_f(Begins at: 345, Ends at:356)
sum_c(Begins at: 289, Ends at:292)
metrics are OK
sum_d(Begins at: 297, Ends at:300)
metrics are OK
sum_f(Begins at: 293, Ends at:296)
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.drain/tinf.h
Class
band3(Begins at: 94, Ends at:99)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Aug 07 11:20:59 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
