[GRASS-QA] GRASS QA: mmetz |global.h main.c read_dxf.c user1.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Aug 7 11:40:40 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.in.dxf/global.h
Class
dxf_file(Begins at: 9, Ends at:16)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.in.dxf/main.c
Function
main(Begins at: 41, Ends at:210)
| New Metrics |Old Metrics|
Complexity: | 17 | ** | BABY-MONSTER | 17 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 66 | *** | MONSTER | 66 |
LOC: | 170 | *** | MONSTER | 170 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/vector/v.in.dxf/read_dxf.c
Function
dxf_close(Begins at: 38, Ends at:45)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
dxf_fgets(Begins at: 83, Ends at:94)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 12 | | OK | 12 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
dxf_find_header(Begins at: 48, Ends at:60)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 13 | | OK | 13 |
metrics are OK
dxf_open(Begins at: 8, Ends at:36)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 29 | | OK | 29 |
metrics are OK
dxf_read_code(Begins at: 66, Ends at:81)
LOC: | 16 | | OK | 16 |
Clone analysis:
File :grass/trunk/vector/v.vol.rst/user1.c
Function
INPUT(Begins at: 63, Ends at:382)
Complexity: | 46 | *** | MONSTER | 46 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 71 | *** | MONSTER | 71 |
LOC: | 320 | *** | MONSTER | 320 |
OUTGR(Begins at: 388, Ends at:782)
Complexity: | 75 | *** | MONSTER | 75 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 114 | *** | MONSTER | 114 |
LOC: | 395 | *** | MONSTER | 395 |
Clone analysis:
File :grass/trunk/vector/v.vol.rst/user3.c
Function
COGRR1(Begins at: 219, Ends at:654)
Complexity: | 74 | *** | MONSTER | 74 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 59 | *** | MONSTER | 59 |
LOC: | 436 | *** | MONSTER | 436 |
POINT(Begins at: 659, Ends at:775)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 117 | ** | BABY-MONSTER | 117 |
Conclusion: | this function is a BABY-MONSTER |
secpar_loop(Begins at: 49, Ends at:214)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 166 | *** | MONSTER | 166 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Aug 07 11:28:08 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
