[GRASS-QA] GRASS QA: mmetz |index.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Aug 10 02:06:04 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/rtree/index.c
          Function
RTreeDeleteRect(Begins at: 262, Ends at:311)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      50 |     * |      WARNING |        50 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
RTreeDeleteRect2(Begins at: 210, Ends at:254)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      45 |     * |      WARNING |        45 |
 at least 3 values are close to an outlier please consider revising code!
RTreeFreeListNode(Begins at: 184, Ends at:188)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
RTreeInsertRect(Begins at: 138, Ends at:172)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      35 |       |           OK |        35 |
 at least 1 values are close to an outlier please consider revising code!
RTreeInsertRect2(Begins at: 81, Ends at:128)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      48 |     * |      WARNING |        48 |
RTreeNewIndex(Begins at: 25, Ends at:32)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
RTreeNewListNode(Begins at: 178, Ends at:182)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
RTreeReInsert(Begins at: 194, Ends at:202)
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
RTreeSearch(Begins at: 39, Ends at:70)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      32 |       |           OK |        32 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Aug 10 01:52:29 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
