[GRASS-QA] GRASS QA: mmetz |spindex_rw.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Aug 10 02:13:22 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/spindex_rw.c
          Function
dig_Rd_spindx_head(Begins at: 79, Ends at:162)
              |          New Metrics           |Old Metrics|
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      84 |     * |      WARNING |        84 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
dig_Wr_spindx_head(Begins at: 23, Ends at:76)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      54 |     * |      WARNING |        54 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
dig_dump_spidx(Begins at: 383, Ends at:399)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      17 |       |           OK |        17 |
Conclusion:   | this function is a            OK           |
metrics are OK
dig_read_spidx(Begins at: 356, Ends at:380)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      25 |       |           OK |        25 |
 at least 1 values are close to an outlier please consider revising code!
dig_write_spidx(Begins at: 330, Ends at:353)
LOC:          |      24 |       |           OK |        24 |
rtree_dump_branch(Begins at: 167, Ends at:183)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
rtree_dump_node(Begins at: 186, Ends at:205)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      20 |       |           OK |        20 |
rtree_read_branch(Begins at: 268, Ends at:302)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      35 |       |           OK |        35 |
 at least 2 values are close to an outlier please consider revising code!
rtree_read_node(Begins at: 305, Ends at:327)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      23 |       |           OK |        23 |
rtree_write_branch(Begins at: 210, Ends at:237)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
rtree_write_node(Begins at: 240, Ends at:263)
Complexity:   |       6 |     * |      WARNING |         6 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Aug 10 01:59:46 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
