[GRASS-QA] GRASS QA: mmetz |port_init.c port_test.c | 2 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Mon Aug 10 02:58:35 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/port_init.c
Function
find_offset(Begins at: 102, Ends at:112)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
find_offsets(Begins at: 114, Ends at:146)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
port_init(Begins at: 148, Ends at:188)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 41 | | OK | 41 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_init.c clones of find_offset are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_test.c find_offset
File :grass/trunk/lib/vector/diglib/port_test.c
Class
type_conv(Begins at: 63, Ends at:71)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
dumpflags(Begins at: 301, Ends at:351)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 51 | * | WARNING | 51 |
at least 3 values are close to an outlier please consider revising code!
find_offset(Begins at: 288, Ends at:298)
main(Begins at: 97, Ends at:281)
Complexity: | 42 | *** | MONSTER | 42 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 37 | *** | MONSTER | 37 |
LOC: | 185 | *** | MONSTER | 185 |
Conclusion: | this function is a MONSTER |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_test.c clones of find_offset are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_init.c find_offset
____________________________________________
Threshold grass key metrics values at Mon Aug 10 02:44:59 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
