[GRASS-QA] GRASS QA: marisn |gs.c GS2.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Mon Aug 10 14:13:44 EDT 2009
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/ogsf/gs.c
Function
gs_att_is_set(Begins at: 149, Ends at:165)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
gs_delete_surf(Begins at: 452, Ends at:465)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
metrics are OK
gs_distance_onsurf(Begins at: 1406, Ends at:1441)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
gs_err(Begins at: 34, Ends at:39)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
gs_free_surf(Begins at: 476, Ends at:535)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 60 | * | WARNING | 60 |
gs_free_unshared_buffs(Begins at: 546, Ends at:577)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 32 | | OK | 32 |
at least 1 values are close to an outlier please consider revising code!
gs_get_att_src(Begins at: 645, Ends at:658)
Complexity: | 3 | | OK | 3 |
metrics are OK
gs_get_att_typbuff(Begins at: 670, Ends at:695)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 26 | | OK | 26 |
gs_get_att_type(Begins at: 619, Ends at:634)
LOC: | 16 | | OK | 16 |
metrics are OK
gs_get_data_avg_zmax(Begins at: 1192, Ends at:1211)
LOC: | 20 | | OK | 20 |
metrics are OK
gs_get_datacenter(Begins at: 1221, Ends at:1270)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 50 | * | WARNING | 50 |
gs_get_last_surface(Begins at: 172, Ends at:185)
metrics are OK
gs_get_new_surface(Begins at: 193, Ends at:216)
CalledNBR: | 4 | | OK | 4 |
LOC: | 24 | | OK | 24 |
metrics are OK
gs_get_prev_surface(Begins at: 86, Ends at:99)
metrics are OK
gs_get_surf(Begins at: 62, Ends at:76)
LOC: | 15 | | OK | 15 |
metrics are OK
gs_get_xextents(Begins at: 1005, Ends at:1011)
LOC: | 7 | | OK | 7 |
gs_get_xrange(Begins at: 1115, Ends at:1142)
LOC: | 28 | | OK | 28 |
metrics are OK
gs_get_yextents(Begins at: 1022, Ends at:1028)
gs_get_yrange(Begins at: 1153, Ends at:1180)
metrics are OK
gs_get_zextents(Begins at: 987, Ends at:994)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 8 | | OK | 8 |
gs_get_zrange(Begins at: 1077, Ends at:1104)
metrics are OK
gs_get_zrange0(Begins at: 1043, Ends at:1066)
metrics are OK
gs_getall_surfaces(Begins at: 108, Ends at:120)
LOC: | 13 | | OK | 13 |
metrics are OK
gs_init(Begins at: 47, Ends at:52)
metrics are OK
gs_init_normbuff(Begins at: 295, Ends at:317)
LOC: | 23 | | OK | 23 |
metrics are OK
gs_init_surf(Begins at: 232, Ends at:285)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 54 | * | WARNING | 54 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
gs_malloc_att_buff(Begins at: 707, Ends at:725)
LOC: | 19 | | OK | 19 |
gs_malloc_lookup(Begins at: 736, Ends at:781)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 46 | * | WARNING | 46 |
gs_mapcolor(Begins at: 958, Ends at:967)
LOC: | 10 | | OK | 10 |
gs_mask_defined(Begins at: 904, Ends at:907)
LOC: | 4 | | OK | 4 |
metrics are OK
gs_masked(Begins at: 922, Ends at:945)
gs_num_datah_reused(Begins at: 586, Ends at:608)
metrics are OK
gs_num_surfaces(Begins at: 127, Ends at:137)
LOC: | 11 | | OK | 11 |
metrics are OK
gs_point_is_masked(Begins at: 1306, Ends at:1392)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 87 | * | WARNING | 87 |
gs_set_att_const(Begins at: 861, Ends at:882)
LOC: | 22 | | OK | 22 |
gs_set_att_src(Begins at: 817, Ends at:847)
LOC: | 31 | | OK | 31 |
gs_set_att_type(Begins at: 793, Ends at:805)
gs_set_defaults(Begins at: 430, Ends at:445)
gs_set_maskmode(Begins at: 889, Ends at:894)
metrics are OK
gs_setall_norm_needupdate(Begins at: 1279, Ends at:1295)
metrics are OK
print_256lookup(Begins at: 356, Ends at:371)
metrics are OK
print_realto(Begins at: 342, Ends at:347)
metrics are OK
print_surf_fields(Begins at: 380, Ends at:399)
CalledNBR: | 11 | * | WARNING | 11 |
print_view_fields(Begins at: 408, Ends at:421)
CalledNBR: | 8 | | OK | 8 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/lib/ogsf/GS2.c
Function
GS_Get_ClientData(Begins at: 1491, Ends at:1501)
metrics are OK
GS_Set_ClientData(Begins at: 1469, Ends at:1481)
metrics are OK
GS_alldraw_surf(Begins at: 1941, Ends at:1950)
metrics are OK
GS_alldraw_wire(Begins at: 1924, Ends at:1936)
metrics are OK
GS_background_color(Begins at: 2454, Ends at:2457)
metrics are OK
GS_default_draw_color(Begins at: 2441, Ends at:2447)
Complexity: | 1 | * | WARNING | 1 |
GS_delete_list(Begins at: 870, Ends at:875)
metrics are OK
GS_delete_surface(Begins at: 1550, Ends at:1578)
Complexity: | 6 | | OK | 6 |
LOC: | 29 | | OK | 29 |
metrics are OK
GS_done_draw(Begins at: 2506, Ends at:2518)
Complexity: | 2 | * | WARNING | 2 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 3 | * | WARNING | 3 |
LOC: | 13 | * | WARNING | 13 |
at least 4 values are close to an outlier please consider revising code!
GS_draw_X(Begins at: 621, Ends at:652)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 11 | | OK | 11 |
GS_draw_all_list(Begins at: 858, Ends at:863)
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
GS_draw_flowline_at_xy(Begins at: 737, Ends at:794)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 3 | | OK | 3 |
LOC: | 58 | * | WARNING | 58 |
at least 3 values are close to an outlier please consider revising code!
GS_draw_fringe(Begins at: 804, Ends at:811)
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 2 | * | WARNING | 2 |
GS_draw_legend(Begins at: 827, Ends at:835)
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 9 | | OK | 9 |
GS_draw_lighting_model(Begins at: 920, Ends at:964)
CalledNBR: | 15 | | OK | 15 |
LOC: | 45 | | OK | 45 |
metrics are OK
GS_draw_lighting_model1(Begins at: 880, Ends at:912)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 33 | | OK | 33 |
GS_draw_line_onsurf(Begins at: 660, Ends at:685)
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 10 | | OK | 10 |
metrics are OK
GS_draw_list(Begins at: 845, Ends at:850)
metrics are OK
GS_draw_nline_onsurf(Begins at: 699, Ends at:726)
ParamNBR: | 7 | | OK | 7 |
GS_draw_surf(Begins at: 1869, Ends at:1895)
LOC: | 27 | | OK | 27 |
GS_draw_wire(Begins at: 1904, Ends at:1917)
GS_get_SDscale(Begins at: 1084, Ends at:1089)
GS_get_SDsurf(Begins at: 1064, Ends at:1075)
LOC: | 12 | | OK | 12 |
GS_get_att(Begins at: 1119, Ends at:1143)
Complexity: | 5 | * | WARNING | 5 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 25 | * | WARNING | 25 |
GS_get_cat_at_xy(Begins at: 1162, Ends at:1212)
CalledNBR: | 16 | | OK | 16 |
LOC: | 51 | | OK | 51 |
metrics are OK
GS_get_dims(Begins at: 2284, Ends at:2296)
GS_get_drawmode(Begins at: 2114, Ends at:2127)
metrics are OK
GS_get_drawres(Begins at: 2260, Ends at:2276)
GS_get_exag_guess(Begins at: 2311, Ends at:2351)
CalledNBR: | 5 | | OK | 5 |
LOC: | 41 | | OK | 41 |
GS_get_focus(Begins at: 2568, Ends at:2580)
metrics are OK
GS_get_fov(Begins at: 2860, Ends at:2863)
metrics are OK
GS_get_from(Begins at: 2730, Ends at:2737)
metrics are OK
GS_get_from_real(Begins at: 2744, Ends at:2750)
metrics are OK
GS_get_longdim(Begins at: 135, Ends at:142)
metrics are OK
GS_get_maskmode(Begins at: 1445, Ends at:1458)
metrics are OK
GS_get_modelposition(Begins at: 515, Ends at:538)
metrics are OK
GS_get_modelposition1(Begins at: 486, Ends at:503)
LOC: | 18 | | OK | 18 |
metrics are OK
GS_get_norm_at_xy(Begins at: 1226, Ends at:1272)
LOC: | 47 | * | WARNING | 47 |
GS_get_nozero(Begins at: 2169, Ends at:2192)
GS_get_region(Begins at: 151, Ends at:159)
GS_get_selected_point_on_surface(Begins at: 2993, Ends at:3427)
Complexity: | 16 | | OK | 16 |
ParamNBR: | 42 | | OK | 42 |
CalledNBR: | 52 | | OK | 52 |
LOC: | 435 | | OK | 435 |
metrics are OK
GS_get_surf_list(Begins at: 1523, Ends at:1540)
metrics are OK
GS_get_to(Begins at: 2800, Ends at:2807)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
ParamNBR: | 1 | *** | MONSTER | 1 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 8 | *** | MONSTER | 8 |
Conclusion: | this function is a MONSTER |
GS_get_to_real(Begins at: 2757, Ends at:2768)
metrics are OK
GS_get_trans(Begins at: 2418, Ends at:2433)
metrics are OK
GS_get_twist(Begins at: 2870, Ends at:2873)
metrics are OK
GS_get_val_at_xy(Begins at: 1292, Ends at:1365)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 74 | | OK | 74 |
GS_get_viewdir(Begins at: 2814, Ends at:2819)
metrics are OK
GS_get_wire_color(Begins at: 2043, Ends at:2056)
CalledNBR: | 1 | ** | BABY-MONSTER | 1 |
LOC: | 14 | * | WARNING | 14 |
GS_get_zextents(Begins at: 2671, Ends at:2682)
metrics are OK
GS_get_zrange(Begins at: 2694, Ends at:2723)
LOC: | 30 | | OK | 30 |
metrics are OK
GS_get_zrange_nz(Begins at: 2361, Ends at:2387)
GS_getlight_ambient(Begins at: 408, Ends at:420)
GS_getlight_color(Begins at: 364, Ends at:376)
Complexity: | 3 | * | WARNING | 3 |
GS_getlight_position(Begins at: 319, Ends at:334)
metrics are OK
GS_global_exag(Begins at: 2004, Ends at:2009)
metrics are OK
GS_is_masked(Begins at: 994, Ends at:1007)
metrics are OK
GS_libinit(Begins at: 95, Ends at:126)
metrics are OK
GS_lights_off(Begins at: 426, Ends at:435)
metrics are OK
GS_lights_on(Begins at: 440, Ends at:449)
Complexity: | 2 | *** | MONSTER | 2 |
CalledNBR: | 1 | *** | MONSTER | 1 |
LOC: | 10 | *** | MONSTER | 10 |
GS_load_att_map(Begins at: 1591, Ends at:1862)
Complexity: | 42 | | OK | 42 |
CalledNBR: | 76 | | OK | 76 |
LOC: | 272 | | OK | 272 |
metrics are OK
GS_look_here(Begins at: 2944, Ends at:2977)
LOC: | 34 | | OK | 34 |
metrics are OK
GS_moveto(Begins at: 2622, Ends at:2645)
metrics are OK
GS_moveto_real(Begins at: 2652, Ends at:2658)
metrics are OK
GS_new_light(Begins at: 252, Ends at:282)
metrics are OK
GS_new_surface(Begins at: 219, Ends at:244)
metrics are OK
GS_num_surfs(Begins at: 1508, Ends at:1511)
metrics are OK
GS_ready_draw(Begins at: 2493, Ends at:2501)
metrics are OK
GS_set_Narrow(Begins at: 552, Ends at:613)
LOC: | 62 | | OK | 62 |
GS_set_SDscale(Begins at: 1049, Ends at:1054)
GS_set_SDsurf(Begins at: 1028, Ends at:1040)
GS_set_att_const(Begins at: 1396, Ends at:1407)
GS_set_att_defaults(Begins at: 167, Ends at:179)
GS_set_draw(Begins at: 2464, Ends at:2488)
LOC: | 25 | | OK | 25 |
metrics are OK
GS_set_drawmode(Begins at: 2088, Ends at:2103)
metrics are OK
GS_set_drawres(Begins at: 2226, Ends at:2251)
Complexity: | 4 | * | WARNING | 4 |
GS_set_exag(Begins at: 1958, Ends at:1975)
metrics are OK
GS_set_focus(Begins at: 2525, Ends at:2536)
GS_set_focus_center_map(Begins at: 2587, Ends at:2615)
metrics are OK
GS_set_focus_real(Begins at: 2543, Ends at:2556)
metrics are OK
GS_set_fov(Begins at: 2848, Ends at:2853)
metrics are OK
GS_set_global_exag(Begins at: 1982, Ends at:1997)
metrics are OK
GS_set_infocus(Begins at: 2906, Ends at:2913)
metrics are OK
GS_set_maskmode(Begins at: 1420, Ends at:1434)
metrics are OK
GS_set_nofocus(Begins at: 2892, Ends at:2899)
metrics are OK
GS_set_nozero(Begins at: 2136, Ends at:2157)
metrics are OK
GS_set_trans(Begins at: 2395, Ends at:2410)
LOC: | 16 | * | WARNING | 16 |
GS_set_twist(Begins at: 2882, Ends at:2887)
metrics are OK
GS_set_viewdir(Begins at: 2828, Ends at:2841)
GS_set_viewport(Begins at: 2920, Ends at:2928)
metrics are OK
GS_set_wire_color(Begins at: 2019, Ends at:2032)
metrics are OK
GS_setall_drawmode(Begins at: 2066, Ends at:2077)
GS_setall_drawres(Begins at: 2203, Ends at:2214)
metrics are OK
GS_setlight_ambient(Begins at: 386, Ends at:400)
metrics are OK
GS_setlight_color(Begins at: 342, Ends at:356)
GS_setlight_position(Begins at: 293, Ends at:309)
metrics are OK
GS_surf_exists(Begins at: 189, Ends at:207)
metrics are OK
GS_switchlight(Begins at: 457, Ends at:468)
metrics are OK
GS_transp_is_set(Begins at: 476, Ends at:479)
metrics are OK
GS_unset_SDsurf(Begins at: 1012, Ends at:1018)
metrics are OK
GS_unset_att(Begins at: 1377, Ends at:1385)
metrics are OK
GS_update_curmask(Begins at: 976, Ends at:982)
metrics are OK
GS_update_normals(Begins at: 1098, Ends at:1105)
metrics are OK
GS_zoom_setup(Begins at: 2777, Ends at:2791)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
void_func(Begins at: 83, Ends at:86)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Aug 10 13:59:55 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
