[GRASS-QA] GRASS QA: neteler |cube_io.c dspf_header.c | no clones |
0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Aug 26 12:12:09 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/dspf/cube_io.c
Function
my_fread(Begins at: 266, Ends at:282)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
new_dspf(Begins at: 294, Ends at:300)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
read_cube(Begins at: 133, Ends at:247)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 115 | ** | BABY-MONSTER | 115 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
reset_reads(Begins at: 284, Ends at:292)
Complexity: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
write_cube(Begins at: 24, Ends at:86)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 63 | * | WARNING | 63 |
at least 2 values are close to an outlier please consider revising code!
write_cube_buffer(Begins at: 92, Ends at:119)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 28 | | OK | 28 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/dspf/dspf_header.c
Function
dfread_header(Begins at: 90, Ends at:143)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 54 | * | WARNING | 54 |
dfread_header_old(Begins at: 145, Ends at:185)
LOC: | 41 | | OK | 41 |
dfwrite_header(Begins at: 7, Ends at:81)
CalledNBR: | 24 | ** | BABY-MONSTER | 24 |
LOC: | 75 | * | WARNING | 75 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 26 11:50:46 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
