[GRASS-QA] GRASS QA: glynn |init2d.c interp2d.c interpf.h
ressegm2d.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Aug 26 12:19:49 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/rst/interp_float/init2d.c
Function
IL_init_func_2d(Begins at: 93, Ends at:112)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 15 | *** | MONSTER | 15 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
IL_init_params_2d(Begins at: 19, Ends at:91)
ParamNBR: | 44 | *** | MONSTER | 44 |
LOC: | 73 | * | WARNING | 73 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/rst/interp_float/interp2d.c
Function
IL_grid_calc_2d(Begins at: 38, Ends at:266)
Complexity: | 27 | *** | MONSTER | 27 |
ParamNBR: | 17 | *** | MONSTER | 17 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 229 | *** | MONSTER | 229 |
Clone analysis:
File :grass/trunk/lib/rst/interp_float/interpf.h
Class
fcell_triple(Begins at: 12, Ends at:18)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
interp_params(Begins at: 38, Ends at:72)
|NEW Metrics | 1 | 0 | 0 | 7 | 0 | 21 |
|OLD Metrics | 1 | 0 | 0 | 7 | 0 | 21 |
Clone analysis:
File :grass/trunk/lib/rst/interp_float/ressegm2d.c
Function
IL_resample_interp_segments_2d(Begins at: 32, Ends at:480)
Complexity: | 56 | *** | MONSTER | 56 |
ParamNBR: | 25 | *** | MONSTER | 25 |
CalledNBR: | 58 | *** | MONSTER | 58 |
LOC: | 449 | *** | MONSTER | 449 |
input_data(Begins at: 484, Ends at:546)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 11 | *** | MONSTER | 11 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 63 | * | WARNING | 63 |
write_zeros(Begins at: 548, Ends at:610)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/rst/interp_float/segmen2d.c
Function
IL_interp_segments_2d(Begins at: 16, Ends at:304)
Complexity: | 37 | *** | MONSTER | 37 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 289 | *** | MONSTER | 289 |
smallest_segment(Begins at: 306, Ends at:337)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 32 | | OK | 32 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/rst/interp_float/write2d.c
Function
IL_write_temp_2d(Begins at: 21, Ends at:143)
Complexity: | 30 | *** | MONSTER | 30 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 123 | ** | BABY-MONSTER | 123 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 26 11:58:27 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
