[GRASS-QA] GRASS QA: hamish |read.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Aug 26 20:17:18 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/symbol/read.c
Function
S_read(Begins at: 230, Ends at:472)
| New Metrics |Old Metrics|
Complexity: | 35 | *** | MONSTER | 35 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 85 | *** | MONSTER | 85 |
LOC: | 243 | *** | MONSTER | 243 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
add_chain(Begins at: 99, Ends at:109)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
add_element(Begins at: 130, Ends at:138)
LOC: | 9 | | OK | 9 |
metrics are OK
add_part(Begins at: 71, Ends at:80)
LOC: | 10 | | OK | 10 |
metrics are OK
add_point(Begins at: 156, Ends at:170)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
err(Begins at: 215, Ends at:221)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 7 | | OK | 7 |
get_key_data(Begins at: 33, Ends at:54)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 22 | | OK | 22 |
metrics are OK
new_arc(Begins at: 173, Ends at:186)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a BABY-MONSTER |
new_chain(Begins at: 114, Ends at:127)
metrics are OK
new_line(Begins at: 142, Ends at:153)
LOC: | 12 | | OK | 12 |
metrics are OK
new_part(Begins at: 84, Ends at:96)
LOC: | 13 | | OK | 13 |
metrics are OK
new_symbol(Begins at: 58, Ends at:68)
metrics are OK
read_coor(Begins at: 189, Ends at:212)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 24 | | OK | 24 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 19:55:48 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
